well, i got the sender installed today with the help of my mazdasport buddies. all we touched was the sender today, cause i had already hooked up everything else. the needle never moved before installing the sender. once we hooked the sender up to the block, i turned the key and the needle moved to 0, but stays at 0. it just sits at 0. we made sure everything was connected properly, and everything is connected right. no leaks, cables are right, but just gets 0. i took the car for a spin around the block, and after a minute or so, i got a CEL. no clue why i got the CEL. we investigate the car again, no leaks or anything. no burning oil smell. that sender is for sure in their properly. so i do the ecu reset trick, take off the negative, and pump the brakes. then we call it a nite, so i drive home, i got no CEL. the drive home was about 15-20 min drive. i also get no oil light. i was curious about the light, is it supposed to come on? the stock sender, we zip tied. and we put the o/p gauge sender right into the block. we have no clue what the problem is. we just know it sits at 0. any ideas as to whats wrong? we are clueless.
