tweakingmsp
- 2003.5 MazdaSPEED Protege
Is there a way to adjust the headlights on the MSP?
If you mean to aim them, there's a small dial on the back of the housing. A Philips screwdriver will do the trick. Park on level ground, about 20-30ft. from a wall when aiming them so you know they are level with each other.
brute force with your fingers work tooIf you mean to aim them, there's a small dial on the back of the housing. A Philips screwdriver will do the trick. Park on level ground, about 20-30ft. from a wall when aiming them so you know they are level with each other.
It does. They seemed to turn easy enough with my fingers for me, but they are tight enough that they won't move on their own.
+1, they moved easily for me when I turned them by hand. Is there an adjustment for side to side though? I believe that dial only moves them up/down.
Use a hammer![]()
