Headlight Adjustment??
If you mean to aim them, there's a small dial on the back of the housing. A Philips screwdriver will do the trick. Park on level ground, about 20-30ft. from a wall when aiming them so you know they are level with each other.
Yep, that's what I meant. Thanks, I'll have to do that in a little bit.
brute force with your fingers work too :D
It does. They seemed to turn easy enough with my fingers for me, but they are tight enough that they won't move on their own.
+1, they moved easily for me when I turned them by hand. Is there an adjustment for side to side though? I believe that dial only moves them up/down.
