mdl247 said:the other thing i noticed since i changed my turbo is that my hks ssqv i like 3 times softer than when i had the stock turbo in. what would that mean? i tried having it vent to atmoshpere more by adjusting the screw and it still is quiter and car stalls lol. even with the dual setup. but gonna tighten tonite cuz to much air goes out.
terbow said:how slow does it build full boost?
check the wastegate, since it has to be modded theres a chance the wg flap isnt seated closed when the cars off so its leaking boost.
terbow said:ur not suppsoed to fully remove any of the backing plate nuts, just loosen them. ur turbo should have came with a little paper with instructions.
terbow said:yea alls the lil bolts do is hold those plates on to apply presure. so u ust need to loosen them. technically u shouldnt need locktite at the moment but make sure its all the way on too, it might be crooked and its leaking? or u have a leak elsewher cause if the turbo is building boost really fast then the turbo and wg prolly isnt leaking. unless its not holding boost.
Brian MP5T said:Ummm, You should be getting excessive wheelspin in 1st 2nd and a bit of 3rd...
That is definately a problem..
terbow said:if ur rolling youd have to have enough tq to break it loose and at 10 psi i dont see that happening unless u had bad tires. id assume its whenu launch it drag racing (like popping the clutch)
Second gear with good tires at 3050 RPM rolling constant speed...mdl247 said:just to make sure we are on the same page. excessive wheel spin when i pop the clutch or just in first gear rolling floor it and then excessive spin?
Brian MP5T said:Second gear with good tires at 3050 RPM rolling constant speed...
Mash the gas and within 0.25 seconds, you should have no traction/wheel spin..
terbow said:interesting, mine never broke loose tuned. i drive like a granny i guess
