When replacing battery, how do I not lose data, settings etc?
Mazda dealer quoted me $260 to replace my battery in our 2019 CX-5. A bit high I think. Costo has Interstate Group 35's, 640CCA, for about $130. I've changed many auto batteries in my life, but I no longer trust myself to figure a, "keep alive," jumper plugged into cigarette lighter socket, etc., to fool the car into thinking all is well and so holds data, settings, etc., without losing them. My local certified independent general machinic is willing to install the Costco battery and seems to feel OK about keeping things running. Question here: Any tricks we need to know about??? Any proceedure suggestions? Thanks, Dennis
No reason to keep it alive. Only thing you will have to do is reset your 1 touch window up and down for driver and passenger. Nothing else will be lost. I’ve replaced batteries on both my 18 and 19 cx-5s with Costco batteries.
You could easily plug a charge booster pak into one of the 'always on' lighter socket. On my CX5 it's in the console and I think the one in the cargo stays on , too.
Thanks everyone. I feel a lot more confident now. And I think I will get the Costco battery.
$130 for a Costco / Interstate Group 35 640 CCA battery? It was $119.99 just a couple of months ago! And it’s now $123.99 in our area. And be aware Costco has no longer offered any “replacement” warranty on car batteries like they used to.
Without plugging in a “data-saver” on your CX-5, you’d lose only trip odometer values and one-touch up-and-down power window settings.
Go to WalMart and get an EverStart Maxx Group 35 battery with 3-year replacement warranty for the best C/P value. They even do installation for you on site for free without the hassle of bring the old battery back for core charge like Costco.
Used to recommend getting the Intestate Group 35 battery at Costco for the best value. But Costco has increased the price from $78.99 with 36-month replacement / 60-month prorated warranty before pandemic, to $123.99 with only 36-month prorated warranty.
2016 CX-5 Interstate battery replaced with Walmart Everstart Evermax
Besides the one touch auto roll down windows, if you have turned off the auto mirror fold in feature it will need to be reset. On my 2022 turbo, those were the only settings that I lost when replacing the battery.
Interesting. On my '21 the mirrors did not revert to the auto fold setting when I changed the battery. Just the one touch windows needed resetting.
I didn't lose any of the presets on my '22 Signature even after the battery went dead for a couple of days before I replaced it... new battery popped in and everything worked as before.
you lose your trip meter and average MPG calculation if you disconnect the battery... you'll need one of those "memory savers" that can go into the cigarette lighter or OBD2 port if you don't want to lose those
unlike old cars, your radio settings are not lost
At work we use whats called a saver. It supplies power through an obd2 dongle. On CX5s, you only loose the auto windows and sunroof, and folding mirror settings if you disabled yours. Disabled fold in mirror is recommended in freezing cold and saves wear on the expensive motor. To reset the windows, push to go down all the way and back up, hold for a few seconds at up. Same for the auto back sunroof.
You also lose both trip odometer values too.
