GT25R Real Potential and Capabilities
nvmsp said:
so is this track really only an 1/8th mile. I mean, you can pretty much tell who's gonna win by then but I don't get why they wouldnt do the full track in okechobee or however it's spelled.
When do u guys wanna arrange a meet down there, I'll go if we get a bunch of proteges there. Ms3,ms6's would also be very welcome.
I had a thread with a date an all and only had Alejo sign up so I cancled the whole thing.
Mazdaspeed2oo35 said:
i like the idea, but why only at 15 psi ?
I was just referencing the comment about the Nick treatment being a good upgrade for the GT25R and it pushes more air than the stocker with the GT28 internals, port/polish job etc.
That's all.
Making 300WHP at only 15PSI was simply showing the potential of the upgraded turbo at over 20PSI it obviously would make much more.
That's all.
it is a good idea, but If i do the T25R upgrade i won't be able to get a bigger, and stronger turbo. but if i deside to buy this upgrade how would this be, where, how much etc ?
avarela86 said:
Yeah, I was in ubber hurry to get to Sears for tools. Crafstman FTW!! I needed a breaker bar and JCELL was heading to my house so I was in a rush. Don't you live in Miami? I was gonna waite for you, I totally recognized you from the stock exhaust and rims.
Your turbo is WEAK, that's why I dissapeared...MUUAHAHAHAHA!!!
Hahaha.. que cabron eres Alfredo...... Well seriously we could make a really nice Miami Mazdaspeed Car Club and hang out and chill, now that we have a track at Okeechobee even go there and race between us and others... yeah i live in miami but i was doing some work upthere this morning..... s*** my turbo is weak i'll race you up hommie and spank your butt..... lol lol........
Tomorrow i'm going to TBK to change my Tranny oil, the Royal purple manuel putted last time sucks dick, its grinding in 3rd gear again. i'm putting back the MT-90 Shock Proof Synchromesh Syntetic Transmission oil is the best oil ever man. Also Manuel tomorrow it's making me the quote for the Big turbo kit, he told me he have a new monster s*** that he want to try in my car to start selling it. so I'm going with Probably the Hiboost Manifold, External Wastegate, 3.5" exhaust and downpipe, since i even lower the compression more to the engine we are going to blow some Massive PSI into the engine, i have 8:3 1 to play with.. and hoping the tranny will hold what's coming in. also he already developed the Tranny internals to hold 600whp+ and driveshafts lets see with what numbers in money all of this s*** comes out so i can just trow in the last things i can put to this car to make it fast, since i already did everything to engine and fueling and cooling system.
shut the **** up miguel, you know i have the fastest protege in reverse around here!!!
i got my car back today, biatch
this will be an eManage weekend
gotta install lots of things
clutch, manifold and eManage
oh, the fun i will have!
anyone up for a challenge?
got beer!
got beer!
Hey b****, I hate when you say hi and bye homosexual, im gonna go to your crib and kick you in the knee. maricon cuando digas HOLA KEEP talking......
here you go buddie,,''
Garrett T25R Dual Ball Bearing Turbo Pushing 18.3 P.S.I of Boost on 106 Octane Fuel, Taking this Turbo a little beyond its Efficiency Limits, this little T25R baby It's Capable to Boost a max flow of 26.2 P.S.I for a few seconds gaining instant whp and wpt with this Mods at the moment: These are the recent Numbers: 271whp & 279wpt 313.6 hp to the Flywheel on Lates TBK Performance Dyno Results as today 01/06/2007
This Numbers had changed do to Lates Tune by TBK Performance 01/06/2007
Adding a Very more Aggresive Air/Fuel Curves, Also Retarding the Timing at High Boost and High RPM to the Haltech E6X Stand Alone Engine Management to Prevent any source of Detonation , Also a Upgraded Hiboost Front Mount Intercooler, 760cc Injectors, cometic thicker head gasket, Mazdaspeed BSpec Low Temp Thermostat from Protegegarage and a few more tweaks that TBK have done to the Haltech.
Engine: FS-DE 2.0 Liter
1. Honed and polished Engine Block. ( Done by TBK Performance )
2. Sandblasted and blackPowder coated engine block. ( Done by TBK Performance )
3. Crankshaft balanced and Polished. ( Done by TBK Performance )
4. Aries Forged Pistons Lower Compression 8.5:1 .20 Over Size
5. Pauter Forged Chromoly Rods
6. Mazdaspeed Engine Rebuild Kit. Main Bearing, Rod Bearing, Etc
7. Cometic Thicker Head Gasket 01/05/2007 Installed New do to Higher Boost Levels.
8. Greddy Timing Belt.
9. Full Head Job, Port & Polish Heads. ( Done by TBK Performance )
10. ARP Head Studs, ARP Washers, ARP Nuts. ( Done by TBK Performance )
11. Bigger Valves & Eibach Valve Springs. ( Done by TBK Performance )
12. ProtegeGarage Intake Manifold Single Runners port & polish. ( Done by TBK Performance )
13. Port & Polish throtle body 60mm. ( Done by TBK Performance )
14. Unorthodox Ultralight S Underdrive Pulley.
15. Gates High Performance Engine Belts.
16. Apex Air diversion Plate radiator.
17. Mazda Millenia Supercharged PCV Valve.
18. Maxspeed Magnetic Oil drain Plug
19. Mazdaspeed 1.3 bar Radiator Cap.
20. Mazdaspeed BSpec Low Temp Thermostat 01/05/2006
21. Mazdaspeed Gunmetal Oil Cap.
22. AWR 70a Bushings Front Motor Mount.
23. AWR 70a Bushings Rear Motor Mount.
24. SR Adjustable Cam Gears. ( Done by TBK Performance )
25. FS-ZE J-Spec 2.0 Intake Cam. ( Done by TBK Performance )
26. Walbo 255 in tank Fuel Pump. ( Done by TBK Performance )
27. Bosch 760cc High Impedance Injectors. ( Done by TBK Performance )01/06/2007
28. Perrin Fuel Rail. ( Done by TBK Performance )
29. Haltech E6X Stand Alone Engine Management Air/Fuel & Timing. ( Done by TBK Performance ) Reprogramming 01/06/2007
30. Haltech 3 bar MAP Sensor. ( Done by TBK Performance )
31. HKS Super Sequential Blow Off Valve Adjustable. ( Done by Dynamic Turbo )
32. HKS Earth Ground Cables System. ( Done by Dynamic Turbo )
33. Mazdaspeed Positive Charging and Voltage Stabilizer. ( Done by Dynamic Turbo )
34. Turbo XS Bypass Valve Recirculation Setup. ( Done by Dynamic Turbo )
35. Injen Ram Air Intake System
36. Apex Aluminum Cone Filter
37. HiBoost Front Mount Intercooler 29 X 6.5 X 4. ( Done by TBK Performance ) 01/05/2007
38. Custom Aluminum 2.5 Front Mount Intercooler Pipes & Flanges. ( Done by Dynamic Turbo )
39. Turbonectics Clamps.
40. Callaway Turbo Manifold Port & Polish. ( Done by TBK Performance )
41. Garrett T25R Turbo Port & Polish. ( Done by TBK Performance )
42. Cork Sport 2.5 S-Pipe & J-Pipe Port & Polish. ( Done by TBK Performance )
43. Mazdaspeed catback Exhaust System
44. Greddy Chrome Oil Catch Can ( Done by Dynamic Turbo )
45. Greddy Chrome Coolant Catch Can. ( Done by Dynamic Turbo )
46. NGK IX Iridium Sparkplugs ( One Step Colder )
47. NGK Coil Packs.
48. NGK Sparkplugs cables.
49. K&N 1008 Oil Filter
50. Royal Purple 20W50 Fully Synthetic Oil
51. Lucas Synthetic Oil Stabilizer & Protection ( New Engine Formula ).
Drivetrain:
52. Fidanza 7.5 lbs Flywheel. ( Done by TBK Performance )
53. ACT Xtreme Stage 3 Racing Clutch. ( Done by TBK Performance )
54. ACT Xtreme Street Preassure Plate Disk. ( Done by TBK Performance )
55. Welded LSD front and back of it, with special coating. ( Done by TBK Performance )
56. Racing Synchronizers. ( Done by TBK Performance )
57. Stronger 3rd & 5th Gear. ( Done by TBK Performance )
58. Techa-Fit Clutch Line. ( Done by TBK Performance )
59. Royal Purple Manual Transmission Gear Synthetic Oil. ( Done by TBK Performance ) 01/06/2007
60. B&M Short Throw Shifter. ( Done by TBK Performance )
61. KartBoy Shifter Bushings. ( Done by TBK Performance )
Brakes:
62. Brembo Cross Drilled & Slotted Rotors. ( Done by HP Motoring )
63. Techa-Fit Stainless Steel Brake Lines. ( Done by HP Motoring )
64. Posi-Quiet Ceramic Low Dust Brake Pads. ( Done by HP Motoring )
65. Royal Purple Synthetic Brake Fluid. ( Done by HP Motoring )
Suspension:
66. Tokiko Blue Gas Shocks
67. Tein S Lower Springs, 2 lower front 1.6 lower back. ( Done by HP Motoring )
68. Racing Beat Front Tower Sway Bar.
69. Racing Beat Front Lower Sway Bar.
70. Racing Beat Rear Lower Sway Bar.
71. AWR Front Lower Sway Bar Bushings.
72. AWR Rear Lower Sway Bar Bushings.
Electronics & Interior Accessories:
73. OEM Mazdaspeed Classic Soft Trim 2 Tone Leather Interior Dark Charcoal with Titanium Gray + Titanium Gray Leather Door Panels.
74. Greddy Profec B Spec-II Eletronic Boost Controller (Silver). ( Done by TBK Performance )
75. Greddy Remote Switching System Steering wheel (Silver). ( Done by TBK Performance )
76. Greddy Full Auto Turbo Timer (Silver). ( Done by TBK Performance )
77. Maxspeed Engine Start Bottom (Blue). ( Done by TBK Performance )
78. Autometer Triple gauge pod (Black). ( Done by TBK Performance )
79. Auto Meter C2 Indiglow Air/Fuel Ratio Gauge (White). ( Done by TBK Performance )
80. Auto Meter C2 Indiglow 20 P.S.I Boost Gauge (White). ( Done by TBK Performance )
81. AEM Uego 6 in 1 Wideband Controller (White). ( Done by TBK Performance )
82. Maxspeed Cluster Indiglow Gauges 7 Colors with Dimmer (White)
83. Street Unit Cluster Polish Rings.
84. Maxspeed Chrome Cluster Bezzel.
85. Mazdaspeed Seat Belts Pads.
Lighting:
86. Euro Black Smoked Head Lights.
87. HID Head Lights Kit. 8000k High & Low Beams. ( Done by HP Motoring )
88. Piaa Clear Rectangular Fog Lights. ( Done by HP Motoring )
89. Piaa Plasma Yellow H3 Fog Light Bulbs. ( Done by HP Motoring )
90. LED Ultra White License Plate Lights. ( Done by HP Motoring )
91. Mazdaspeed Carbon Fiber License Plate Frame. ( Done by HP Motoring )
Wheels & Tires:
92. 2006 Mazda RX-8 Shinka Edition Wheels 18 X 8. ( Done by HP Motoring )
93. Nankang Ultra Sport NS-II Tires Z Rated 215/35/18. ( Done by HP Motoring )
94. Gorilla Chrome Wheel Nuts. ( Done by HP Motoring )
95. Gorilla Chrome Wheel Locks. ( Done by HP Motoring )
damn,thats a ass load of labor you paid for.
did you do anything on you car yourself?all this done,and you can't really be proud of much more then saying "I spent a lot of money"
How Many People from Miami, Want to Join a Car Club I'am going to make my self, and probably with the help of others like my boy Alejo_NIN our backyard mechanic? we can hang out, Race, talks s***. hit each other. lol jjejeje.. Seriously I've notice nobody has come out with this idea. we can make a real nice club, and once in a while visit others from others clubs and share ideas, talk s*** and why not race each other, in the track or where ever .... we have to keep this mazda love .... any mazdas are welcome,, one THING... NO bad SRT-4 admitted... lol J/k........
lets see how many of you are down to do some real s*** in this boring ass community
1. Mazdaspeed2oo35
2. Alejo_NIN ( He Better !!!! )
3. SergMSP ( another one that Better Join !!! )
4.
5.
6.
7.
8.
9.
10.
Edit the list who are interested on doing some serious s***...
Well, I Did the Forged internals and all of that crazy ass mod list with my Boy Alejo_NIN. i just paid for the HALTECH intallation and tuning, Injectors, fuel Pump welding lsd. etc.... the rest we did it in the backyard of my parents house. we not only myself are proud of the results.. didn't you already told me these like 4 times before ?
avarela86 said:
There's that beer again...
Jaime is gonna own MUCHO people. I can't waite!!
Este maricon, always saying GOT beer, and then he don't drink. and probably no beer at all... ALEJO_NIN we are all going to kick your ass si no tienes beer.
hey Alfredo, PM me your phone number..
Royal Purple is actually a VERY distinguished brand. I wouldn't say it sucked. Which one did you try?
You fogot to mention "lightweight" shock proof... I have the same stuff, works pretty well when REALLY hot. Not so great when cold.
It's the same Manifold I have with a "special" turbo. I know what it is but he doesn't want me saying it much. Should be the same one that is in Superproteges.
Yeah we talked about it a while back when he was first in the process with Juan. I want a set as well. I am a tranny killer...I wish we had Honda trannys, they synch so well.
Alejo_NIN said:
got beer!
JCell said:
i'll run ya as soon as i'm done :D
yeah, but for Engine OILs which i use myself i use 20w50... i but for the tranny it sucks dick. i had the MT-90 and no grinding in any conditions..
47. NGK Coil Packs.
Drivetrain:
Brakes:
Suspension:
Lighting:
Wheels & Tires:
Damn. Thats alot of s*** to be making about the same hp I did and Joep did with all the stock components, good exhaust, and some know how.
505zoom said:
Man, not to sound like a prick or anything, but I just lost all of the respect for your car that the mod list had earned for it. Paying some shop to do everything for you takes every ounce of fun out of modding a car in the first place.
Still a nice setup though, good luck with it.
This coming from a guy that drove how many miles, how many times, to get parts installed on his car?
yeah, but what its holding me down its the turbo and exhaust, once i do my turbo and exhaust upgrade.. boommm i'll jump to a crazy ass level.. i'm doing my upgrades very soon... and make a video of it.
Joep made 263whp on the stock turbo and a homemade 3" exhaust, stock everything else.
I went 13.15 with pretty much everything stock, except the exhaust, and few tricks.
i've said this don't know how many times. I DID everything on the list with my boy ALEJO_NIN in the back of my parents house. just paid to install my haltech, welded lsd, and tune the car....in a dyno.. to be honest this car has all the respect from the people that we work in.. Alejo_NIN, TBK, and My self..
