Grinding noise when steering to the right
We started getting vibration and grinding noise when turning to the right. I assumed it was the rotors. Put on new rotors and pads. Didn't fix the issue. The sound is coming from the front driver's side. Any ideas?
Thx,
-PJ
Likely it is the bearing. Rotor and pad usually does not make noises when you turn it left/right.
Bearing, however, is stressed side-way when doing that.
I am having an issue with grinding during left turns. Just curious, how many miles were on your bearings? Im at 55K.
