Fsck You.
Lil Freek said:
i still say you find him and stab him.
He will be taken care of next time I see him; out of the car.
Note to him: If you're on here, I don't get pissed easily. However, when you put my life and those of others in jeopardy intentionally and I'm around..
Heh.
t3ase said:
Whoever has a yellow MSP that was rolling around on 183 tonight and had a red Nissan Sentra next to them, needs to die.
I was trying to tell you you had a nice car when you and your fuckhead "ghetto fabulous" passenger flipped me off and sped of like a dumbass, only to cut in front of the Landcruiser. The Landcruiser then had to slam on the brakes, causing me to swerve around.
You are a ******* moron and I hope to hell you read this so next time you'll know I'll have no problem beating some ******* sense in to you.
did he have any type of mods you could see so we could identify him?
last night i was just hanging and playin halo cause i had my last final this morning, and the only other yellow msp i know here in austin lives about 3 minutes from me, and he's an older guy who has actually waived at me a few times.
we must find this unloyal msp brother and take him out.
there are somo msp owners that are really ******* retards LOL last time i wasn't tried to race the same car but a silver msp with exhaust , alteza tailights rev up the enginge so laud that one cop pulled him over and he told the cop that i was racing and show him when i go so got pulled over and get a fuking ticket for illegal racing almost $600.00 and i never find him . i understand you LOL
t3ase said:
oh,and to whoever that was... wear your ******* hat like every other human.
you are not fiddycent.
*clears throat* its fiftycent and he is human so if he wears his hat like fifty then thats like a lot of other humans.
yeah...but those humans look like schmucks
Well no s*** its "fifty". Do you say "fifty-cent"???
Doubt it, most pronounce "fiddy"cent. Hence the spelling. I am sure Tease isn't a ******* retard, get off his ass!
And just because another human wears it that way doesn't make this douchebag right. That is like saying oh I am cool, my collar is popped just like Kanye's! No, you're a dickwad, go get a job and A&F.
NAME
fsck - check and repair a Linux file system SYNOPSIS
fsck [ -sAVRTNP ] [ -C [ fd ] ] [ -t fstype ] [filesys ... ] [--] [ fs-specific-options ] DESCRIPTION
fsck is used to check and optionally repair one or more Linux file systems. filesys can be a device name (e.g. /dev/hdc1, /dev/sdb2), a mount point (e.g. /, /usr, /home), or an ext2 label or UUID specifier (e.g. UUID=8868abf6-88c5-4a83-98b8-bfc24057f7bd or LABEL=root). Normally, the fsck program will try to run filesystems on different physical disk drives in parallel to reduce total amount time to check all of the filesystems.
If no filesystems are specified on the command line, and the -A option is not specified, fsck will default to checking filesystems in /etc/fstab serial. This is equivalent to the -As options.
The exit code returned by fsck is the sum of the following conditions: 0 - No errors 1 - File system errors corrected 2 - System should be rebooted 4 - File system errors left uncorrected 8 - Operational error 16 - Usage or syntax error 32 - Fsck canceled by user request 128 - Shared library error The exit code returned when multiple file systems are checked is the bit-wise OR of the exit codes for each file system that is checked. In actuality, fsck is simply a front-end for the various file system checkers (fsck.fstype) available under Linux. The file system-specific checker is searched for in /sbin first, then in /etc/fs and /etc, and finally in the directories listed in the PATH environment variable. Please see the file system-specific checker manual pages for further details.
chuyler1 said:
NAME
i see someone else is bored at work, too!
Waiting for stuff to compile.
We got a Sun machine that requires you to run fsck whenever you reboot it. The Ultra10...Sun's poor attempt at making an IDE based desktop machine. I've got the command memorized for this reason.
tis the reason i use it.. thanks.
who the **** are you?
