I still need to send you that oil pump.
Question on the FS-DE oiling system.
I'm a n00b to this motor. I daily drive my P5 and want to protect it for spirited street driving. It has 125k miles on the original motor, would replacing the factory pan with the AWR help me at all? Does the pan hang super low? I wouldn't want to scrape the AWR pan on the ground at all after I lower the car.
I'm just trying to do preventative maintenance that won't put a dent in my pocket.
Pump finally sent!
I see. So what you're saying is if you don't plan on driving in a spirited fashion for more than 10 minutes the stock pan would be ok? I would upgrade the pump but have no means or the need (at this time) to remove an otherwise perfectly running motor. Also, I hear you have to have the full AWR motor mount package to install this pan, due to there being very limited spacing and if the engine moves slightly it was clunk against other parts.
I plan on getting an oil pressure gauge soon to monitor oil levels, wouldn't hurt to know what's going on. Also, do you recommend 5W-30 in these or 10W-30?
Hey Tom.... I show that my oil pump has arrived there, on friday. Can you just confirm this and maybe give me a heads up as to when you want me to paypal, what the estimated time of completion is and what cool hat I can have?
I'm not in a huge rush, just wanna know it got there safe and that this lowly canadian isn't going to be forgotten...
Thanks.
	I want the Hawk one! Thanks for the compliment, you have a PM. All I did for the cleaning was to use a fine wire attachment in a cordless drill, and our industrial parts washer... I'm now working on my MBSP to get it the same so I can weld fittings for my turbo drain and your ExPRV....Your oil Pump has arrived and was opened for intial measurments. You have been PM'd with the specs and information.
Since you were the first to take advantage of our new FREE HAT OFFER you have your pick of which hat you would like!!
Your pump in our shop with the assortment of hats to choose from.
BTW, great job on cleaning your oil pump!! (yes) I thought it was a brand new one at first!!
And don't consider yourself a "lowly Canadian", most of here at Doc B Racing consider ourselves part Canadian since we spend so much time in Canada racing in the Canadian Touring Car Championship with the MSP!
Payment sent! Sorry about the dirty pump.
can you provide some good pics of the setup?
