FREE MPI help!
terbow said:
your talking about the blue on the TM right. im talking about a resister on the blue MPI wire and grounded to the Black MPI wire.
If u dont want to list it thats ok, i just didnt think it would hurt to add incase someone gets one. i mean i did.
OH, you're talking about the blue MPI wire, NOT the TM wire. Okay I got you now, because there should ALWAYS be a green TM wire. What was done there was the same as what thegreen TM wire does.
yea i figured as much but i called nick to make sure cause it wasnt my car.
yep, we had four people working on an MPI install and we found wires wrong on the 2nd or 3rd review
We made everyone review the wiring 4 times each...
can you guys tell me what wires should be left over from the module,and MPI,the not used wires?
moduole should have none left over.
mpi should have 3 i think. the injector driver wire, the map toggle wire, and one more, id have to go look.
ok well nick changed the setup. so, if they have u not hook up the purple ones, then yea youll have purple, but theres no consistant setup so its hard to say whats left over, but the 3 i installed so far the tm wires are all used.
the mpi itself had like 3 left over.
I got the purple ones connected, i have the two greys one map switch and the other extra injectors and I thought there was a few more???? can't remember
i thought there was only 4, but like i said, id have to look. its all buttoned up so ill see what i can do later.
there should just be extras on the mpi tho, the tm should all be used unless u were instructed to not hook certain ones up.
On the TM, there should be NONE left over, unless you have yellow wires. If you have purple wires, then hook them up. The newest ones don't have purple wires, so non should be left over. The MPI has 4-5 wires left, I don't know for sure off the top of my head, I'll check for sure later. But whatever is in the instructions is what needs to be hooked up, unless you do not want to use the toggle switch for the maps.
purple left over is ok, according to recent setup changes. i dont know if ur supposed to use em or not. it seems to change in every post i read.
You will have 2-blue w/black wires, a gray wire if you do not use the toggle switch and a gray w/black if you do not use xtra injectors. So a minimum of 2 and a maximum of 4.
If you HAVE the purple wires, then hook them up unless Nick has told you otherwise. Nick told me the new ones do not have purple wires. So if you do have them....hook em up. He has compensated for the lack of the purple wires in other ways with the new TM. So hook whatever you have up or you risk not getting enough fuel.(thumb)
then why do I have an extra grey?
I have extra injectors set up,and functional,and I have my toggle set up,
GRY/BLK used for injectors,
GRY for toggle
GRY unused
GRY for toggle
GRY unused
This MPI does not have 3 gray wires. Are you sure it's an MPI wire? Here are what wires are in the connector. Wires 14 and 15 are not used at all.
No one has any questions they want to ask on the forum? I still get PM's and calls about stuff, but no one posts the questions. Come people, spill it!(thumb)
Also, I thought I would post the SW and key up for people who need it. (since I'm asked for it as well.
Added the new SW
I read the cd set up and it looks hard how often do you find yourself changing your map? how did you find a good base map to start of with because that stuff had me feeling like i was in a math class!
I don't have a mpi or MAM SS yet but hope to get mines later this month.
There are a lot of people on here that have a map that would probably work to get you started. Since you have a DX, My map will probably help get you started with your SS and MPI. I will adjust it for you to start out in case you don't have extra injectors like i do.
