GMalatrasi said:Thanks guys... One more question: I'm a lil confused as to what/how exactly the extra injectors set-up works. Is ti really an additional injector added to the fuel system? where does it go? couldnt I just get bigger injectors?
I guess it was more than 1 question...
GMalatrasi said:Okey doke... Thanks
Moeed said:The ones I posted. I bet your turbo module is missing the green wire. Let me know if it does. Just have to add a different step.
For the bigger injectors, just run the stockies. When you get a bigger injector that sprays more fuel, the ecu wont know the difference and it will bog bad.
The nice thing about the mpi is it lets the stock ecu still run the car, So everything works.
Tim, yup, had the older setup.
GMalatrasi said:Well I'm not sure which box is the turbo module but both the black and the gray boxes have at least one green wire.
GMalatrasi said:Another Q about the extra injector set-up:
How do I get fuel to the extra injector?
Do I split the fuel line before the fuel rail or what?
Would that reduce the amount of fuel going to the primary injectors?
wicked said:you put the extra injectors inline with the stock,and no it won't take away from the others.
GMalatrasi said:What exactly do u mean inline?
Does anyone have pics of this set-up?
Moeed said:I can take a pic of my set up. It has the fuel pass through.
You can get it from Nick.
My wires look different, but those look pretty beefy.
