sniper9 said:i turned the switch off and because im using dual aux injectors. I turned the fuel Cal down to -2 right now and some bucking went away. Before at about 11.5-12 afr it would buck so maybe I was maxing out the stock injectors? It cold right now here maybe about 40. The car just feels really really slow for running 12psi on a gt28rs...
Can you describe the bucking? Is it like a cut or just bog down?
Be Careful, bucking can be:
1. Running lean in some spots
2. O2 clamp NOT working
3. Pump starving
4. Not enough fuel pressure
5. Wide gap on spark plugs
6. Too much ignition advance
7. Too much fuel
8. Failures on electrical connections
