II-Savy said:The turkey is NOT from compressure surge. Compressure surge or compressure stall does not sound like our turkey noise. The turkey or flutter noise is not the turbo being forced to go the wrong or opposite way. It would sound much different ....
and I too am looking forward to the release of this BPV.
Petey Turbo said:I can't believe people argue this..If the turkey was coming from the wastegate, how could the sound travel out of the WG flapper, through the turbine wheel, through the shaft, out the compressor wheel,and out the air intake??It is compressor surge..Even the whopping 7psi of boost we run is no match for the monster of a plastic BPV we have..I used to get compressor surge after using the 2 inch diameter TIAL BOV on my galant if I shifted under 10-15 psi,15-30 psi would make it crack open with vengance...If you want to make the turkey go away, put the right BOV on there and make sure it is set right..And BTW when people say an external WG makes a similar noise thats wrong too..Flame away
II-Savy said:I'm not going to keep saying it. Even Callaway said it was not surge. This may be all semantics, it may depend on what you mean or think "surge" is.
TiGrayMsp716 said:Forge in looking to make some samco style IC hoses for the MSP. If anyone cares to DONATE them that would expediate the process. For everyone one that whines about no one makes s*** for our cars. Here's your chance to help.
