Fog light Help
speed6r
2006 Black Cherry MS6
Anyone know what fuse controls the fog lights? My fogs are out and I doubt its the bulb's. Any help would be appreciated. Thanks!
The fuse switch on the stalk?
Check it, make sure it's got continuity when its flipped to 'on'.
No offense to your knowledge, but if you installed the bulb yourself and touch the bulb, this could severely limit the life of the bulb. Just another possibility. Other than that, bumper to bumper should cover this, I would think...
No offence taken. I did'nt install the bulbs they're stock to the best of my knowledge. i'm trying to avoid the trip to the dealer if at all possible. any other advice?
Yes, the MS6 uses H11 fog light bulbs.
To the OP, did you ever figure this out? Did you happen to check the relay in the fuse panel under the hood? Another possibility of problems there...
