Falsely overheated
Hmmm that could be your problem.
If it doesn't snap back into the plastic connector then it might be bent or something.
Try removing it from the plastic connector then remove the plastic connector from the ECU and plug it directly onto a pin on the ECU to see if its snug on the pin.
That's where you scavenge a pin from an unused wire from the big connector and use it for pin #91.
Or get a connector from the wrecker to remove a pin from it to use.
You cut the connector off with a few inches of wire to splice into it.
Then you'd have a whole bunch of pins to pick from.
The problem is that you can't test for continuity between the little metal clip and the pin of the ECU once the connector is plugged in without taking the cover off the ECU and finding the backside of pin #91 to test the connection.
It's possible to solder the orange wire (white in your case) directly to the inside of the ECU and bypass the connector for that wire, but that's pretty involved.
I'm pretty sure that is the case.
Her car spontaneously died so the O2 sensors, throttle position sensor and transmission fluid temp sensor may all have failed.
Yep, either that or the main relay failed, fairly common in early Miatas as well. The INJ fuse powers the ECU and a host of other devices.
The "ground" return at pin 91 is not the same as chassis ground, BTW. For a quick test one can ground the orange wires to chassis ground to see if there is an open circuit but I wouldn't run it that way; the ground loop created can make the ECU do all kinds of funny things.
Loss of power to the ECU can make engine quit suddenly.
She did have a mechanic look at it and he most likely checked fuses and relays and everything seems to be working on the dash except the temperature gauge reading max.
I was wondering about that but I didn't know if the sensor ground is even connected to chassis ground
The mechanic did check the voltage at the temperature sensor and I don't think it would have had any voltage at all if there was a blown fuse or bad relay?
The ECU probably needs to be powered up fully to send voltage down that purple/yellow wire to the temp. sensor.
That's why they return all grounds to a single point. You could have several millivolts between sensors if each was grounded separately.
I wonder if there is continuity between pin #91 and the ECU ground?
Now I want to remove my ECU and check to see. Lol
Maybe I will, then I can offer mihkayla some comparative measurements.
If she gets a multimeter, we can compare notes. Lol
Fortunately, none of these systems are actually used so you don't have to worry about them. Lol
Ohhh...
Wrong Page...
Holy Crap!!
At least I found a bunch of dirty money. Lol
The ECU looks to be rust free...
I found a couple of connectors under the hood that has an orange wire...
I removed half of the engine to pull a piston so I don't know what the connectors connect to.
But one has a violet/yellow wire so it's probably the temperature sensor.
I took the cover off my ECU and found this...
And this...
I found pin #91 on the backside of the circuit board.
I can trace the wires back to the ECU from the sensor connector.
Notice the Orange wire...
I tested for continuity between pin #91 and the four B/W pins and there is continuity between pins # 24, 51, 76, and 77.
If the OP were to tap the orange wire into one of those ground wires, would that create a ground loop?
They are all grounded together within the ECU.
I guess if it didn't matter then that orange wire would just be another B/W wire and grounded with the others?
I found this too.
There are more sensors connected to the orange wire.
hello again!
so I haven’t been working on my car because I kind of gave up lol but I was wondering if replacing the ECU all together would be something to consider? I found one at picknpull for $78 and my brother had suggested that could be something to try incase that is burnt out and not the wires.
I don’t want to spend the money if it doesn’t seem like it’ll do anything but if it could then i’d be willing to. just wanted to get your guys take on it
It's possible that your ECU is the problem, but now you've still got that orange wire to deal with.
(I will admit that I had my hand in that).
A New ECU won't fix the problem if your orange wire isn't fully connected.
Fix the orange wire first (check for continuity), before replacing your ECU.
Holy Crap !!
Check out my parts car...
The same stupid s*** !!!
I figure it's some kind of clandestine MOD or a very common problem that I don't know about.
Ok, maybe it's done from the factory?
I still think you need to feed that orange wire from the ECU to all your sensors.
I think you should do some testing first before you spend the money on an ECU.
Don't forget to try and ground that orange wire from the temp sensor to the engine or frame to see if your temp gauge goes down.
The mechanic that looked at your car suggested a burnt wire as well and I would think that if your ECU was bad, you wouldn't get a "High" reading at the temp sensor.
