Ya its pretty bad... As long as you don't floor it.. the cop shouldn't smell it until hes probably 1 - 2 cars behind you (while cruising). I'd just custom weld a hi-flow cat if possible.bsgts said:after putting on a downpipe does it give out a bad smell? is it strong enough for the cops to smell it and pull you over?
I've got a 3" S pipe back and yes it stinks. but SO worth it.bsgts said:after putting on a downpipe does it give out a bad smell? is it strong enough for the cops to smell it and pull you over?
Smells like fuel. Everyone with downpipe w/o cats have that problem. Even some Hi-flow cats will stink a little but its still legal.bsgts said:does everyone with a downpipe have this problem? hwat does it smell like
No Just the unburnt fuel is usually absorbed by the cat's...bsgts said:do you burn more gas with a downpipe?
How much do you get on the streets? Currently im getting 25 mph on the streets with fmic/d/p/exhaust and intake. Also i like to hit it a couple of times here and there.GotBoost said:my gas mileage stayed the same except on long highway trips. i get MUCH better gas mileage. about 35 mpg on a trip from Ft. Laud, FL to Savannah, GA.
Yesbsgts said:does it backfire and then make a loud poping noise
jersey...what kinds of gains did you get? Also, I've read so many things about downpipes, i can't keep all the info straight. With a dp/high flow cat, will you get a cel and/or can you still pass inspection? Basically, I'm not sure if it's the dp that has the o2 bung or if it's somewhere else.jersey_emt said:I have the Apex downpipe with high flow cat. No smell, a slightly deeper/louder sound, and on rare occasions, a little backfiring
jersey_emt said:No CEL, should pass emissions.
Awesome power gain...the car pulls much harder...and it pulls all the way to redline.
