LOL you moron. What came first, the mechanic or the technisian? I believe they were called mechanics. But that wasn't P/C enough. They go these tech shools so they started calling themselves technicians to make them sould official. But like I said, not just 10 yrs ago the techs were the goffers of the shop. No unless you were a mechanic 10 yrs ago (which by the way that would put you at 10yrs old and Iracemine at 17) I don't think you know enough to comment on it.
And quit changing you posts.
Mazda_maniac said:he tried to be good but he still does not read full posts or forums. If he'de look at more than just one factor, Most performance pads nowadays have channels which do the job of getting rid of the brake dust. Therefore if the dust is aloready channeled out and the gasses are not being created due to the newer technology that means no use for cross drilled. You are somewhat right in one case, I will try to pound this at you til you try to open up and look deeper. By you saying Technicians are the walmart brand look into a dictionary tell me which one seems like it says their a little more knowledgable and then tell me why they changed itto technician. Your experiance helps yes but sayinng i'm the kid down the street does not. You started this whole controversy with witt.
Main Entry: 2mechanic
Function: noun
1 : a manual worker : ARTISAN
2 : MACHINIST; especially : one who repairs machines
Notice only repairs.
Main Entry: technician
Pronunciation: tek-'ni-sh&n
Function: noun
1 : a specialist in the technical details of a subject or occupation <a computer technician>
2 : one who has acquired the technique of an art or other area of specialization <a superb technician and a musician of integrity -- Irving Kolodin>
Specialization.
You tell me which sounds better. I'm sticking with my argument and that's, that I can understand that they were useful when pads gave off gasses readily and at lower temperatures but with the new compounds much higher temperatures must be reached for this, if at all possible. Tire rack says not intended for high speed track use... the time when it'de create the most heat so that tells you something else, not that its just a disclaimer. With less surface area there is less to conduct heat so the pad is concentrated with more of it.
