DaveMS307 said:Or both![]()
DaveMS307 said:Actually, the rotors were not defective at all. Carbotecheng.com (great race/track day) pads recommends against drilled rotors for use with the more aggressive pads.
You dismiss my advice to the original poster incorrectly. I still KNOW that for my car with Carbotech pads (which completely eliminate fade and dramatically improved performance) cross-drilled rotors of any brand will not work well. This was the experience of everyone I talked to running on track on a regular basis running similar setups with cars that were out-brake everything on track. My opinion is that a good set of solid rotors and great pads (Carbotech XP series are amazing) are the best choice.
I only post this because I've been reading your posts and think your responses, while they may not intend to be, come across with a lack of respect for the original poster.
I will probably regret posting this follow up, but hey I'm bored waiting on the trick-or-treaters to ring the bell..
Happy Holloween to all.
Hughes412 said:Well I did read all of your post and I even skimmed over them again, but it's kind of hard to tell what you posted seeing you've edited almost all of them in the last few days.
And even if you didn't say that, one of you did and you didn't dispute it.
I'm not a brick wall by any means. There are several (I wont look for them) threads were I was proven wrong and not only admitted it but even apologized for it. But I know in that Im am right. Yes you are right in the fact that I do not have the money to do a study on the issue. But I dont feel I need to see that
ITA ALL READY BEEN DONE!!! HELLO!!!!
Yes I posted links off of performance sites that are in the performance business. Those would be some of the people that did the research.
But to address what you say you DID say. If I read it right you are saying that the D/S rotors will not absorb the heat that the pads make there for the pads will heat up and cause them to glaze or gas out. Well thats what the holes and slots are for. If that happens it will help you cool off the pads. The rotors can only absorb so much heat transfer before letting it go or cooling off. The holes will help in that process. And like you said, the technology keeps changing. So the pads get better. So a really good pad and a really good Drilled and Slotted rotor (kind of like the one Porsche used) will be even better.
And one last thing. Look up Ferrari and Lamborghini or Saleen and so on that us them. I think I asked once but incase you didnt read it. Do you really think that they would use a rotor on a 100+k car if it didnt stop the car (which by the way is very important)? Do you really think they would pay their engeneers to use useless rotors?
Now I apologize for making fun of you. I can see that you are very sensitive. But you did start it off.
Rac3rX said:I have 55k on my car (55 thousan KILOMETERS), Ive had my stock rotor spun twice already, and they are too warped at this point for me to even consider another spin (if there is even enough life left for that)
Ive replaced the pads twice, remember 55k
My rotors are so ******* warped that at 120klm/h I get a slight woble (very slight)
When Im braking it wobles a bunch and as Im slowing to a stop, you can feel the brakes come on and off (no they are depressed) but the pad loses contact with the rotor because its so ******* warped, and when there is no contact there is no stoping.
My Rotors get TOOOOO ******* HOT!!!
Soo you keep bitching about losing braking efficiency because the holes or slots reduce the surface of the rotor, But really do you think the efficiency is HURT SO BAD by that diff of surface that it makes a noticeable difference? HELLL NO! Do you think that negligible difference (IF any) is worth having fade, no consistency out of the system and warping rotors? You keep your rotor surface
If you dont think there is any issue, go out right now bring her up to 180klm/h, slam on the brakes, get off the expressway and cut some corners with those rotors and pads real hot, Ill post my condolences afterwards.
Ohh and if your like "who does that" Going 180klm/h then hitting the brakes? s***, well..... spirited drivers....... I feel spirited when I bring her arround 100mph and sometimes you need to slow down quick......
Hughes412 said:Were you aiming that at me? If so that only helps my point. If that's what you ment cool. If not I don't quite get your point. But it is early.
Oh and I have 55 thousand miles on my stock pads and about 30+k on the Brembo rotors. I have had to touch them once. And people on this very forum can tell you, I don't drive normal.
But I'm safe!(first)
Mazda_maniac said:
Mazda_maniac said:Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if these products are used on the track they are not warrantable
Mazda_maniac said:you guys are missing the point, email tire rack and ask truthfully then first you state that these people say they benefit braking, now your saying its a disclaimer?
iracemine said:dont think i said "not appropreate for high speed track use" that was the reason for makeing theis rotors in the first place FOR lemans cars in the 40s and 50s. my old man had a gullwing 56. that thing could beat the s*** out of most cars today on the track. BUT times have changed, did you go from a stock rotor to S/D rotor to come up with your opinion OR have you tryed stock vs premium plain, and premium plain vs S/D. no didnt think so.
cons: waist of money (over the price of plain premium rotors with upgraded pads WHICH ARE MUCH NEEDED FOR SPIRTED DRIVING), lost of heatsinking ability, the verey littil risk if ******* ever that they will crack, increased pad wear( big deal to thoughs who want to get more for their mony)
dont think this is from tire rack but just want to show you other poeples veiws since more is stronger that two.
"But what about cross drilled or slotted rotors? Well the common belief in the main stream is that somehow slotted or cross-drilled rotors allow for better performance by handling heat. This is 100 percent false. The individuals involved in such fallacies mention that air through the holes or slots work to cool the rotor (convective heat transfer into the air from the rotor). The issue is that from physics we know that metal transfers heat better then air by a significant amount. As such the larger mass of the rotor becomes more important then the larger surface area of the rotor in any situation other then the optimal. Cross drilling and slotting rotors are not optimal manners of creating metal to air transfer through larger surface areas. There is not much airflow through the holes or slots. Furthermore for cross drilling the holes will fill with brake dust in effect lowering the cooling ability of the rotors vanes they pass through."
like i said lets take one aspect at a time please pick one. not in a tower, but merly on the side of majority thanks. oh and dont just scream at us go and talk to some race teams that race smaller cars after all thats why were here to talk about car stuff with other car peeps. love you.
