hope someone can give some insight to my problem:
a few weeks back i changed out the plugs and wires in my 02 p5 and dropped in a new K&N air filter in hopes of improving gas mileage and bringing back a little more zip to the performance. reading through the board, i got the idea to reset the ECU in order for the car to "start over again" with the fresh sparks. i disconnected the battery, pumped out the brakes, hooked her back up again and all was good.
until....
periodically, not everyday or even very predictably, the car begins to act up. while driving at highway speeds, the front end will begin shaking horribly, enough to vibrate the entire cabin let alone the steering wheel. while that sounds initially like a wheel/suspension problem, it also comes along with a palpable loss in power. RPM will stay up, but the car simply won't respond or accelerate. it feels as if the car wants to stall out, but it doesn't. it may drive like this for a few minutes before it returns to normal. like i said, not constantly and not very predictably, though it seems to happen more when the car is cold and at highway speeds (though i've had it happen in town after driving highway home too).
any ideas? the only thing i can think of before taking it in for service is to try resetting the ECU again.
02 p5
112K miles
all stock except as noted
new timing belt/water pump maybe 9000 miles ago
new plugs/wires
until....
02 p5
112K miles
new plugs/wires
