Crossover question.
Brahma12
If I have my Subs crossedover at 80Hz they shouldnt play notes above 80HZ
So if i use a 90-120hz test CD my subs shouldnt do anything correct?
What if they do?
Are my amp's crossovers crappy?
My amp is a Cadence Z7000
It depends on what the slope of the crossover is ,I believe Cadance uses a 12DB /OCtave slope on their xovers ,that is if you have your xover set at 80hz one octave higher(160hz) will be will be 12db lower in volume . In answer to your question ,yes the subs will pay if you use a 90-120 hz test tone although at a reduced volume .
On a side note try setting the xover for your fronts to 120hz and reduce the bass on your head unit by a couple of steps . this should help clean up the midbass ,our cars have a peak enhancement in this range .
^^^ good info;) different x-overs have different slopes. most amps are 12 dB per octave, although some are 6 or 18, even 24. with a higher value, you can get more precise cut off at the desired freq.
the JL has switchable 12db / 24db
gotta love all the fine-tuning you can do with a JL amp :D
why not save your money by purchasing a less expensive amp that puts out the same power and get something that gives you real tuning, like audio control products? (braindead
2 swords...damping factor. JL has >500...pretty sick if you ask me. Sooo much control of the sub. Makes for a very clean signal...plus, JLs still pound when you need them to. At least...that's been my experience...but I'm not one to flex my quarter panels. :)
:eek:
I didn't pay retail for it :D
not to mention, nearly the same wattage no matter how you configure your subs 1.5 - 4 ohms ;)
from 250-500 you won't notice a difference in control over the sub;) it's when you drop down to like 100 that you notice a difference (blah) and if it's that important, get a US amp with over 2500 dampening factor (smoke)
see thats one thing i never liked, 500 watt amp. run it 4 ohms its 500, run it 1 ohm it's 500 watts. i think i'd prefer a 500 watt amp that does 750 or 1000 at a lower ohm load.
I really like my JL amp also. just makes things simple. they have alot of powerand are underrated.
the other thing i was thinking about for them, is what about when you compete? i know they are changing the rules around this year and what not, but if the amp is rated at 4 ohms and 12 volts, and it does just a little more than that at say 1 ohm, it would suck ass. take the great cheater amps that do a couple hundred watts at 4 ohms, 12 volts, and will put out well over 1,000 at 1 ohm and higher voltage;)
Good point. but I dont compete. I just like to listen to nice music. I want it to look nice when I show someone. be reliable. that kind of stuff.
got wake? said:
and i like to save money and have more power (smoke)
i'm looking into getting the PHD3. with simple mods it will run up to 18 volts, and crank out over 6k watts;)
save money. that thing is 1500. that is sick. but I guess you need alot of power for that damn monster in yoru trunk. have you heard teh saying.. " sounds like to midgets wrestling in the trunk" well you are going to sound liek the midgets are having wrestel mania back there.. heeh.. good luck.. maybe when I get out of school.. I will get a chance to catch up with soem of you guys and hear some s***.. maybe even that beast of yours.
actually i can get that amp brand new for under $900, and off e-bay for around $600;) if i'm going to pay over $1500, i'll get the PHD4 that's 6k watts rms for $2k online, retail of $2800 (omg) i might be selling the 18. i've got a couple people interested in it, and i can sell it for double what i paid for it;)
nothign wrong with making money. I aint mad at ya. those are some good prices. you can figure if you are getting your power for less that 1 dollar per watt you are doing good.
got wake were you around when orion came out with there amps that were 1/4 watt at 4 ohms. but put out around 1000 watts at 1 ohm.
i wasn't around back then. it wasn't till '97-'98 that i really started getting into systems. hell, i'm only 22;) i'm thinking about fixing my autotek 330MXi that's rated 165x2 at 4 ohms, but was bench tested at over 2k watts into 1/2 an ohm:)
