InlineTwin said:
I do have a few more nagging questions. And I hope this is not just irritating, I think it is very cool that a shop such as yours would even bother to respond on a forum like this. You clearly have good talent at your organization.
Thanks a lot! And I don't mind the questions at all! That's why I'm here, so throw them my way if you've got 'em!
InlineTwin said:
My first question is where is the 450 HP coming from? Really the stock core could push 450 HP through it, not efficiently but it could. So what is your decision point for the number given? This is in response to the seemingly conflicting marketing decision not to post dyno results, but to post a max HP support of your design.
That's a great question. The 450hp rating came from a flow test of the intercooler core. The manufacturer forces air across the core until they measure a 1-psi pressure drop, indicating that the flow was becoming restricted. They then took the airflow rate and calculated how much horsepower (theoretically) could be made.
The truth is that this is a very conservative rating, and it is also somewhat arbitrary in our opinion. There are so many variables that need to be considered: End tank style, passage length, air temperature...none of these things were specified to us when we ordered the core. So when we first started testing, we were a bit skeptical of their rating. But after looking at the data, we think 450hp is still a good estimate of the core's potential.
But you're 100% correct. Technically, there is no true rating of how much horsepower a core will support, since it all comes down to what efficiency you're willing to live with. But judging from our data we're confident that our FMIC design will maintain it's 70%+ efficiency rating well into the 400hp range.
InlineTwin said:
Less expensive, probably not in R&D, but in final production cost very likely. And I said the leading edge of the hood (or at least that is what I meant), which is very different situation than the lower bumper area. Has cp-e compared the delta P between the LE of the hood at the intercooler intake point vs. inside the engine compartment below the IC and that of the FMIC location to the area behind the radiator? (with/without the fans on) It is harder to determine, but most interesting is the mass air flow across the intercooler, any comparisons there?
I wish I had data to throw at you, but I don't. We believe that the static pressure built up in front of the car at speed isn't drastically different between the lower grill area, and the intercooler inlet. You may be right that the presure is slightly higher at the TMIC inlet, but we'd argue that the ducting negates this pressure difference, if it exists at all.
InlineTwin said:
That is what I am getting at. Most drivers will inevitably be in a vacuum while driving at speed, which is by far the most activity the car is likely to see. Traffic lights are not generally considered a tree.
I think we're agreeing, but disagreeing on this point. My point is that once you lay into the throttle, the intercooler is immediately put under a large thermal load. You're saying that 99% of the time, people are just cruising and out of boost, which is true. But people don't usually install performance parts so they can cruise better, they install them in order to make more power, which only comes into play when you mash the throttle. So you're right, if all you do is drive to and from work and never really lay into it, then this wouldn't be a good upgrade for you. But every time you lay into the throttle, that stock top mount is
not happy.
InlineTwin said:
LOL, not that the DRIVER is in a vacuum (happens occasionally)...just heading off any witty responses.
I never even considered that, but the mental picture had me laughing out loud (lol2)
Jordan
