- '13 CWP MS3 & '16 Mazda6 GT
so should be poking at any of the ignition & alarm module w/ this thing?
peepsalot said:I have one, it really doesn't output enough heat for larger applications because the heat is wicked away too fast. very small soldering it is ok, but kinda clumsy to use, cause you have to touch both sides of the split tip to whatever you are soldering. And yeah, sensitive electronics will get screwed up by it since all it is doing is running high amp current through the material you want to solder.
Hey flat_black, I don't think I've ever seen a pic of your car, is it really flat black, just curious what it looks like.
