Thanks for the info Blenercloud!! I downloaded Winrar, now I just have to get the map file(s) onto the Accessport Manager. Maybe I'm moderately computer dyslexic but I'm having trouble accomplishing this task. Any input? Anyone? And a couple other questions:
1) Are the maps on mzspd.com 'safe'? Any input from Cobb on their design? Are these all Access Tuner Pro maps?
2) With the mods I'm running, which map(s) would be most suitable?
3) Should I be expecting the poor gas mileage that I'm getting currently running Stage 1 +SF 91 octane w/ my mods?
4) Off topic - how often (on average) should the Cobb intake be cleaned?
Thanks in advance for any and all input!!
1) Yes, they are safe. (I don't have any other information about the other two questions.)
2) You should be running the Stage2 93 v101p 900rpm idle.
3) Yes, poor fuel economy is expected and is my experience with removing exhaust backpressure and running a Stage1 map. If you do exhaust modifications, you really need to go to Stage2. With just a test pipe on Stage1 I dropped to 19mpg. When I moved to Stage2 I'm pushing 25.5 city and almost 34 highway.
4) I would clean the filter every second or third oil change. That is probably even 'too often', but it keeps you in the habit of cleaning it.
As far as your problem importing goes, here is a walk-through:
1) Unzip the map by right-clicking on it.
2) Open AP Manager
3) Click File and then go down to "Import Maps to Library"
4) In the dialog box, go to the directory where you unzipped the map and select it.
5) Refresh the map list in AP Manager by either selecting your AP (on the left menu bar) or close out the program and re-open it all together.
6) Once your new map is in the "APMgr Library", click on it and drag it over to your Cobb AP in the menu on the left.
After that, you should be good to go!
