I have another OEM Sedan Lip available...this time brand new with all mounting hardware...
PMed.
Something new just arrived!!
Nice, thats on my to do list as well.
This is an OBX...however even the OBX's aren't 100% worry free...most issues I believe come from people cross-threading the EGR pipes in the first place...
I was lurking back a few pages and I noticed the post about trunk leaks. Mines leaking too. Anyone have suggestions on where it would be coming from?
the seam under your tail lights is the likely cause, if the car has ever had any contact in the rear they open up or over time the seam sealer shrinks. Remove the rear lights and you'll see the seam right at the top of the bumper.
Mine is leaking from the protege emblem on the back left side. Might try checking that
Oh okay. Where is that flap located at?
I got the same leak but mine came from a seal under the car behind the strut. Check if the seal under there is open. Once I sealed mine. Water never got back in.
If you remove that black surround you'll see that the flap is attached to it. My idea was to get a piece of plastic and seal it to that black surround and then seal the surround to the metal. Since it hardly ever rains here in Texas I've been pretty lax about getting to it though. I believe if you look from the underside it's between the quarter panel and the frame.
