Bulb burned out
prix
I need a new low-beam bulb, does anyone have any recommendations on where to get one online? I've been very busy and don't know where to start? I also don't know the part number or where to find it... Thanks in advance
h7 bulbs for the p5, h4's for the regular protege. you can buy em pretty much anywhere. just head down to your local auto store and pick up a pair! and welcome btw:)
It might also be a good opportunity for an upgrade. I got Luminics Titanium white headlight bulbs, Luminics yellow fogs from Street Unit, and am pretty happy with the results.
http://www.**********.com/luminics_s/27.htm?Click=125
dont mean to thread jack but could someone explain to me what the difference is between the luminics bulbs and that other stuff that costs hundreds of dollars and you gotta get a kit for, or would I need that kit to be able to use these bulbs? I was thinking of getting the white bulbs but dont know if they just a direct replacement for the stock bulbs.
Another thing now that I noticed, will these even fit my 02 ES?
Luminics are a headlight bulb upgrade. Remove the stock ones, replace with the Luminics.
HID bulbs are a kit with even brighter bulbs,and are a very good upgrade if you have $300 to upgrade the lights. They are different technology than factory style bulbs, requiring some wiring work to install them.
good luck changing the cock suckers, my gorrilla hands wont even begin to fit, both my low beams burned out 4 monthes ago, i am unable to replace them. at the moment im looking for a how to on how to remove my bumbper so i can get at the bulbs(pissed)
lmao, I could not do it either! I had a friend with small hands do the passenger one, because the the washer fluid fill neck was in the way.
LOL so you have been driving around with no headlights or using your high beams for 4 months?
hey, anyone know if I can add the yellow luminic fogs on my fog lights for my 02 ES? and when I looked at the list on SU i didnt see a listing for the regular protege, should I be looking at the MSP ones to be sure they are the same or the MP3?
I have large hands and it took me 5 minutes to change both bulbs. You are probably doing something wrong.
The washer fluid bottle can easily be "bent out of the way slightly" using a sutable amount of force to give a little more room to maneuver.
It really is a piece of cake.
how could I find out if they fit? would taking out the bulb label them as H3? or could one of those books from pep boys/autozone that have the listing for bulbs for all cars have it? Do they sell these luminics at either of the stores or equivalent?
So what is the difference between these and normal bulbs? What is the price difference? Are those the annoying blue tinted bulbs that blind you when they are driving behind you?
Thanks again.
Needle Nose Plyers
