What is the largest tires you can fit on a stock 2017 with the 19s? I was wanting to get 235/60/19. Thanks.
I'm a newbie.
I'm a newbie.
Don’t need 255, my 225/55R19 stock Toyo A23 will rub the front struts:For 255, you might want to make sure there will be no rubbing against the wheel walls when it is fully turned.
