My owners manual says 5w-30 is the recommended oil if I am out side usa or canada? (oh s***, yes another oil thread) england? norway? iceland? telling me the 0w-20 is just for the CAFE stats, and the engine will be just as happy (happier?) on a bit thicker oil. all comments welcome!! (how do I download a "beating a dead horse" emoji?
https://en.wikipedia.org/wiki/Corporate_Average_Fuel_Economy
This is a huge can of worms.
My father has driven millions of mines. He used to drive for a living. He ran Mobil 1, Amsoil, Pennzoil, Castrol, and probably some that have gone out of business since then.
I am also not prone to following my father, just because he is my father. That said, I did learn a few things from him.
Pennzoil crapped up an engine badly. Sludge everywhere (He tore them all down when they failed or drank too much oil. 302ci Fords usually went around 200-300K miles or so (variable), and the 281ci Fords (4.6L SOHC) would be good for around 225-250k miles or so.)
Anyway, he began running Shell Rotella 15-40, because it is a diesel oil, and it prevented sludge. Torn down engines looked GOOD! Very clean.
When I got my first car, I just did as my father had. I got 170K miles out of my LT1 Trans Am with narry an issue, running 15-40 Rotella T in it.
That said, upon further research, it is my OPINION that thicker oils do not protect better. They only flow slower. Now, this is a MODERN engine opinion. If you have a diesel or a flat tappet cam, disregard. Oil provides boundary film lubrication. Which is to say, parts "float" on an oil cushion and do not have metal/metal contact. Ergo, the faster you get oil to the parts, and the better it flows, the better it will protect the parts, so long as the tolerances of the engine are such as to retain good pressure across the bearings (with your oil weight) and so forth.
Now, this "10-30" crap. Stop. Just stop using that measure. It's like me saying "put gasoline in the car". Well, if it's a Z06 Corvette and you put 87 octane in, your life will suck. So I say "Put "XX octane in".
This is the same with oil. Most 10-30 is thinner than most 0-30, for example.
If you want to accurately discuss the viscosity of oil, use centistokes @ 100*C (operating temp). That will allow you to intelligently compare viscosity of two or more products.
Now...back to your question, OP: Follow the owner's manual. use what it says to use. Because why not?
