2013~2016 Knock noise from CX-5 front
CombatSailor
2015 Mazda CX-5 Sport 2.5, 150k miles
I have a knock from what seems to be the front drivers side at slow speeds when going over bumps. It's sporadic. I replaced the control arms that included ball joints and bushings. Also replaced the front struts. No movement to the steering wheel or vibration just the noise. Tires are wearing even. It's been to two mechanics that haven't been able to track down the issue. Any ideas?
Solution
UPDATE: MY KNOCKING/CLUNKING IS FIXED. IT WAS THE CROSSBAR UNDER THE WINDSHIELD/next to strut mount bolts.
Scroll up to my previous comments/video for the sound/issue, I was 2 seconds from ordering new struts thinking it was the struts. I tightened the crossbar bolts as some others have noted and the knocking has gone away, so anyone else with similar sound, please try this. I can’t believe the number of hours I spent trying to diagnose and fiddling around with my strut (threw bunch of lithium grease at it) only for it to be the crossbar.
BAD NEWS: I snapped off one of the bolt while tightening it and the one next to it seems to keep turning and I’m afraid to cross thread/snap it too, so I’ve got more work to do.
Anyone know the...
I just had both my left and right LCAs replaced with aftermarket brand, now i'm hearing a knocking when accelerating from a stop initially. If I go slow it's usually ok, but if I accelerate a little faster, it knocks. I have a 2016 with 101K. Mechanic looked at it and replaced one of them and still knocking. Anyone have a fix?
This sounds like some engine mount to me...
Upvote 0
I had mine fully checked last week, with similar kind a noises from below. Already had Droplinks, Tie road ends, lower control arms changed and still there.
They`ve luckily managed to find some faults. 2 different knocking clunking sound there was, 1 of them was a rather large stone stuck in between the car and the subframe... made quite a noise, 2nd of the noise was the break caliper going bad. They can go bad from where the pin is inside, and need to get a new one. It was fully screwed on the secured, but it was still loose making noise any time the road surface changed. Now both of the noises are gone :)
Upvote 0
