2022 CX-5 Non Turbo Oil Dilution?
I have a 2022 2.5L non turbo CX5. At about 20,000 miles and 4,500 since my last oil change I got the low oil indicator notice in the app. Checked the dipstick and yes it was low. I added a quart and I already had an appointment for an oil change at the dealer the next week. They took a look at it and said there were no leaks.
After that I began manually checking the oil ever other gas fill up. At 4,000 I noticed it was getting low and figured in another two weeks the notice would come back so I added about 2/3 a quart. Scheduled an oil change and discussed the issue with the service manager.
The service manager listened and basically said there is a known problem with the turbo models (which I knew) but not the non turbos. He offered to do the oil consumption test ever 1200 miles but did warn me that while he didn’t agree but Mazda would most likely say that a quart ever 4,000 is normal.
Just had my second 1200 mile check and it was normal but the service manager did say that with in the last few weeks Mazda has changed their tune and has told dealers that if the customer is losing oil and they want the seals replaced that it would be covered.
My question is, should I let them do it? I don’t have the most faith in most dealer techs when it comes to tearing an engine down and am concerned they may end up doing more damage then if I just kept adding oil every 4000 miles or so. Or am I just over thinking this and its not that big of a job and should just let them do it?
There's been people on this site that had the job done by the dealer and I don't remember any complaints. If it were me I'd have it done.
Hopefully some of them will chime in.
Upvote 0
I had a car with bad valve stems seals. It would smoke noticeably under a couple of condtions>
1.If the engine was thoroughly warmed up, shut down, then restarted after sitting a bit
2. After coasting down a long hill then when you touch the gas again.
The oil builds up in the cylinder head in these situations and then you can see the smoke burn off.
Some people switch to a heavier grade oil, like 5w30, to reduce oil consumption.
Upvote 0
Just learned about this potential issue since coming back from a trip with our new to us 2022 CX5 (early Sept.). I'll be keeping a much closer eye on the oil level. My heart sank when the "oil can" indicator came on. Checked the level and it was just above the low reading, put almost a quart in and light went off and has been off since (about 900 miles). Going to the Dealer Wed. for an oil change and will ask the Service Dept. about this. This is a non turbo bought with just over 13K miles currently showing around 17500 (Can't see any signs of a leak). I must be getting naive, our 2014 Mazda 6 didn't use oil, now we spend 28K for the CX5 and it seems to use oil.
Upvote 0
Did you mean to write Oil Consumption in the title? I was looking for something regarding dilution and was losing my mind not finding it.
Upvote 0
ouch-do you do many long trips or normally short runs?
if you look at your owners manual you will see 5w-30 is factory fill for cx-5 except for Canada/US,
Upvote 0
