2018 CX-5 Transmission fluid change question
7 liters??? If your dealer did the drain-and-fill for you they’ve made some money from you by exaggerating the ATF amount! You need less than 5 liters even if the dealer dropped the pan to replace the filter cartridge.
No it’s a filter cartridge / strainer there, not a fine screen.
Cut open:
Don’t do that. See my previous post.
Sorry my friend you must have quantities mixed up, right out of the service manual and I have no idea how your has a paper filter unless it was done already once. Mine was a fine mesh screen right from the dealer.
(Approximate Quantities)
Capacity
Automatic transaxle fluidSKYACTIV-G 2.57.8 L (8.2 US qt, 6.9 Imp qt)/ 8.0 L (8.5 US qt, 7.0 Imp qt)
SKYACTIV-D 2.28.0 L (8.5 US qt, 7.0 Imp qt)
[th]
Item
[/th]​
Capacity
[th]
Item
[/th]​
These specs listed in the manual are TOTAL capacity for each transmission. You won’t be able to drain all ATF out from an automatic transmission as almost a half of it is resided in the torque converter、oil passage、and differential chamber which can’t be drained out from pan plug. And Mazda OEM filter cartridge / strainer FZ01-21-500 for SkyActiv-Drive transmission definitely is not a fine mesh screen.
Again, if you did ATF drain-&-fill by yourself, you couldn’t drain out 7 liters of factory ATF from pan plug.
Here is the ATF filter cartridge / strainer for Mazda’s SkyActiv-Drive automatic transmission showed in Mazda’s Workshop Manual:
It’s not a fine mesh screen.
Interesting. Must be different per transmission? For the MX-5, the ATF should be 136—144 °F.
That is different. Maybe because there' no dipstick? The procedure states 7 liters, but I think they probably mean total fluid amount in the trans for component replacement or major repair.
Good info. Definitely need to do 2 or 3 drain/refills given the amount of oil that circulates in the tranny. Similar to what I've done on my 13 Lincoln MKX.
