- Mazda
So many thoeries..... without more information....
First if you have NO DTC then your OBDII diagnostic connector is damage or the ECU is failing. I don't see anything that would indicate that. So no Engine check light move on.
A spark plug even new can start to have a performance issue. Only an oscilloscope can see this happening not the milage or brand. Trust me when I can show that a spark plug of any brand degrade after 5k miles and continues to degrade. So don't necessarily rule them out. Here again if they fire then it is not so likely to generate a DTC. Not all engine issues as you described will generate a DTC. Simple things like a dirty MAS or MAP of even the throttle body can cause problems and NEVER ECU generate a DTC.
I highly doubt it is a clogged fuel filter because if it were then your engine would have fuel supply issues causing a lean (AFR unbalanced beyond ECU tables adjusting limits) condition at a specific % of throttle that would generate a DTC. And your description on the fueling does not really point to the fuel filter. If I were looking the fuel pressure would be more my attention. But again if the fuel pump were going bad there would be a AFR adjustment in the ECU beyond limits which would and should generate a DTC.
Using any cleaners in the fuel tank would not be the best at this point and may actually exacerbate the problem. If the thought is faulty or fuel injectors function not operating within limits well most will always generate at least the basic P0300 DTC which is nothing more then anomalies out of programing condition of engine operation DTC. You don't place a band aid on a cut that may need stitches.
I recommend NOT guess and start tossing parts at the issue and look at the parts that are already there first.
If you cannot use a proper way of acerating the problem in a manor that will eliminate without adding problems that take your Mazda to a service shop.
Just saying.......
Just saying.......
