2010 Mazda3 Lights Pulsating while stopped
Greetings,
2010 Mazda 3 155k miles. Automatic Transmission with manual shifting option.
TCM was replaced 4 months ago by AAMCO. Recently while in gear and stopped by brakes, there seems to be a "Pulsation". The dash screen (displays time, temp and radio station), headlights and brake lights pulsate when stopped. The instrument panel illumination does not, nor the radio/AC illumination.
You can also slightly feel the pulsating through the brake pedal, but the RPM needle doesnt move at all.
Ive seen Service Bulletins online for 2012 and later for TCM/ECM reprogram. Not sure if its covered for a 2010 with a newer TCM??
Greetings,
https://koko.bet/sports/
I’ve seen that before — usually it’s the alternator starting to weaken or a poor ground connection.
Check the battery terminals and grounds first, then test the alternator output at idle. If voltage drops below 13.5V, it’s probably time for a replacement or at least new brushes.
