Also, the weird thing is, the EBC shims seem like their plastic, you would think they would melt.
I used the factory shims on mine with the EBC greens..
This is how I figure out if its the front or rear. If your steering wheel shimmys while braking, it's the front rotors. For the rears, you usually feel it more in the seatback.
My Centric rotors now make a god awful squeel only when backing. They also vibrate now when braking at high speeds. I am going to replace them this weekend with EBC Greenstuff Pads and these rotors from E-Bay: http://www.ebay.com/itm/160663619403?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_5480wt_1185 This time I am replacing Front/Rear so I have matching rotors and pads all the way around. I hope it holds up better. I was using the Centric Ceramic Pads on the Front as well.
How many miles on your centric rotors? Mine squeak when backing as well, a minor annoyance, but I suspect this is due to me tossing the factory brake hardware kit (shims) because having a double shim makes a cracking noise every time you let off the brakes from a stop and hit the gas.
It doesn't matter what you use. I replaced all 4 of my rotors and it stays quiet for a while then the squeal comes back and it always happens in reverse only. The dealer keeps greasing these things every time I go for full circle service during the recall which I went twice for. One for inspection of the control arms and once for the replacement of said control arms. I noticed that when they grease the brake hardware that the noise stops for a few days. Once it rains it starts again. It is especially louder on rainy days.
After a few years, MY OE brakes have finally bit the bullet. Great thread for info here. Planned on getting some Centric blanks. But after reading the thread, probably will just go with StopTech's as thats what ive run on my other Mazda's without issue in the past.
