mspeed03point5
- 03.5 mazdaspeed
ya, just quick pop, and then it bounced like a rubber ball
soundbombing said:
RAAZ227 13s will be nice, just to see it on the time slip. Good luck with the sti, my friend has one. Still learning how to drive with the awd, power, and race tires. He already bent a rim and control arm.
mspeed03point5 youll get use to the car and learn how to drive it. I sucked @ first and was mad b/c it was kinda embarrassing. I use to launch at all different kinds of rpms and either it would bog or spin and have wheel hop. I would suggest getting the front motor mount changed so you can launch around 3000 rpms. That is where about I launch right now and feather it.
soundbombing said:InsidiousMSP I was running @ 14 psi. I wish I had an exhaust but its stock right now. I think I would run a 13.8 if I had the exhaust done if not faster. Im pretty sure Ill be in the really low 13s with some drag radials along with the exhaust. I want to upgrade the clutch in the near future, I think that will help a lot. What psi were you running for the 14.3 run?
MPREZYA said:Yeah my friend was pissed because his fuel tuning got messed up once he turned up the boost on his FP Green turbo (T4 wheel in a mitsu center/exhaust). For being on pump gas it was pretty good and with the MPH he's definetly worthy of mid 12's. I have a feeling once he's tuned it may be possible for low 12's @112-114mph on 91 octane. Race gas look out.
I also think I've seen your MSP around El Camino Real as it was one of the first I had seen locally (at least 6-8months ago). I vaugely remember seeing the FMIC with dealer plates still on it.
[edit]Know what I think we have some mutual friends as I was at that show you have video of your car in the MI booth. Do you happen to know Mario who was there talking with Brian (the guy with the White WRX in their booth also).
