In southern Wisconsin, you can't get anything but the 10% blend. I know it's required in Milwaukee, and it's everywhere in Madison as well.
Well the Milwaukee and Madison area also require emission testing, everywhere else in Wisconsin they don't require that so that's where you usually see the 100% premo gas.
Did you read my previous post....Your milage did exacty what it was supposed to.
E85 does not produce the same power or Milage per gallon and is also a lot cheaper per gallon.
And your knock sensor was likely going off because you did not tune for E85 which requires apprx. 30% more fuel for the same power level.
Its not plug and play with that stuff..there are some changes that have to be made.
It's decreasing our dependency on foreign imports + burns cleaner... regardless of price. That and it's 85% renewable.My question is WHY? If it doesn't reduce the price and because it's taking our cornfields to produce it and causing problems there, shouldn't we stop?
Eventually they'll start making this stuff with switchgrass with more enzymes to reduce the production energy/costs.
It's definitely not the be all and end all source for a cleaner fuel, but it's a good start.
There are multiple options that would reduce our dependency on those who currently control the oil supply. Ethanol is one. Biodiesel is another. Good old-fashioned car pooling and *gasp* mass transit if it's available (notice I didn't say convenient or timely, just available) are even more options. Combining errands so you make one trip, not multiple. The list can go on.
I'm not a hippie,though I do like to hug trees (but that's probably my Druidic ancestry at play there), but I have an issue with drilling in the ANWR in Alaska. We've fuc&ed up so much in the US environmentally already that I'd hate for us to do it there too.
And buttthrax, watch the ethnic slurs.
But with the amount of seismic activity they have up there, doesn't that just open the door for all sorts of mechanical/structural failures?
(and I will read up on current drilling processes...knowledge is power)
price of gas is also being driven up by other modernizing countries mainly china and india.
edit: Case in point, look at Gov't schools. The principles can't even use a paddle on the children anymore. Teachers cannot fight back. This leads to rebellion. (Wow. Star Wars much...)
