Can someone help - Xenon vs Halogen
My original headlights are Xenon bulbs; both left and right are stripped (can't adjust the height)
There is A pigtail from the car that has to be plugged into the ballast.
I bought a used replacement, but it has halogen headlights (not xenon).
My ballast pigtail from the car has no connection because Halogen doesn't need a ballast.
Will the halogen headlight work without plugging the pigtail that connects to the xenon ballast?
Below is the picture of the original headlight with Xenon ballast.
The next picture is the halogen headlight that I bought. No ballast.
The last picture is the wire/pigtail from the car for the ballast.
Thank you.
Thank you.
I connected the non Xenon headlight and it did not work.
Can someone help, how can I use the halogen headlight.
Halogen is a standard filament lamp that burns brighter than standard incandescent lamps which light in a vacuum.
Xenon should be a two wire setup.
Ballast lamps will need a power supply for higher voltage.
Two pin socket should be 12 volts dc.
Use that for the xenon.
