Looking to sue Mazda in a class action
STARTING A CLASS ACTION
I’m looking to start a class action against Mazda for their brake system malfunction. I have a 2022 Mazda cx5 with indicators that my parking brake system has malfunctioned, my smart forward city braking system malfunctioned, my forward sensor malfunctioned, and another braking system sensor has malfunctioned. My car is still under warranty but I am looking for others who have this problem or had to pay for this fix. I also had the power steering come on with this issue
This is causing the car to not set the parking brakes correctly. It is also causing the automatically slam its brakes in traffic without a car actually being in front of mine at times. The sensor is deploying emergency brakes for no reason and it is a safety hazard. I also am hearing squeaking of the brakes.
It would be much less expensive for you to get your car fixed than to initiate a lawsuit. You're not going to find many people on this forum to join in with you.
No it’s not cheaper. This is a huge problem and it has affected many people with this car. It costs nothing to get the lawyer in these types of lawsuits
do you have the data to back that up? most issues I have read about are where people don't read the manual and do not know how they work.....show the data
I strongly suggest you start the process. You have my full unequivocal support.
Just 1 thing to remember: If its thrown out, the counter party remember can sue you back for trying to malign their brand. Just a thought.
I would suggest that before you start this process, you first need to determine what's causing the issue, what the fix is, and whether Mazda is covering the repair under warranty.
I think you'd need this information in order to determine exactly what your lawsuit applies to, and what resolution you want Mazda to take. At the moment, it sounds like one or two different problems may be occurring, a sensor issue and brake noise.
I'm not sure you'll find many members here who have had experience with this particular issue, especially because there isn't enough specific information for what is causing the problem and what the fix is or how much it costs. From what I've personally seen in my time on this forum, the emergency braking is usually a result of the driver making assumptions about whether the car ahead, which is making a turn, will clear the lane in time. I have seen one or two cases where the car mistakes oncoming traffic on a curving 2-lane road as a vehicle in front, or a very sunny day causing glare that triggers an error when the sunlight hits the sensor just right, but nothing where the car just suddenly emergency brakes for no apparent reason.
I recommend that you bring the car in so that the dealer can diagnose the issue and repair it. At that point you'll have more specific info, and you can use that additional info to properly poll the community.
Shocker that the OP hasn't come back. LOL. He thinks there are many others with this issue? His post about it is the first I have seen on any Mazda forums.
To be fair, it's been less than a day, and it is possible that they're having this exact issue with their car. With such an unheard of issue in the CX-5, it's much more important that they get as much info as possible before moving forward with a lawsuit.
It also sounds like the front radar sensor is bad. Unplug it, take the car which is under warranty to the dealer and get it fixed.
There was a similar word for word post on the CX50 forum about six months ago.
For what it's worth, something to look for. I was just dealing with an intermittent brake warning error for the past few weeks. I never saw it myself, only seemed to happen when my wife was driving to work early in the morning.
Parking Brake, Radar Cruise Disabled, etc. errors cycling through on the dashboard. She was able to get photos, and I saw one of them mentioned low brake fluid. Once I saw that, I knew what was happening. The rear brake pads were worn to a point where the brake fluid was dropping in the master cylinder just to that point where the low level sensor would kick on. When that happens, it must trigger all the other warnings. I had pads on hand from last time I inspected and saw they were getting low. Slapped them in and good to go. Once piston was pushed in all the way, the fluid level was probably back to 3/4 of the way up.
Did you check brake fluid level? Do you know the condition of the brake pads? Ours is a 2022 with about 40k miles. You say you're hearing squealing, maybe your rear pads are worn out and it's lowered the fluid level below the sensor?
That is really interesting. I will remember that one. Not that I'll be running the Akebono ProACTs down anytime soon since I expect 100k out of them and I put on 4-5k / year...💀
Rear brake squeak is a common complaint of the 2nd gen cars. Mine is doing it and it's still practically new. Car has 8.5k miles and the pads have 4k miles on them. I'm not sure what the source is, haven't bothered to look into it as it only does it when first backing out.
I just took it to the dealer!! It’s crazy how they said everything was fine. Mazda is in contact with the dealership. Because they don’t want to do the repairs under the warranty without charging me more money but Mazda has escalated it and has been sued recently for the bigger model car for this issue!
So, what did the Mazda dealership service department say when you brought the car in ?
They didn’t want to check the vehicle and look at the issued without me spending a ton more money. So I reached out to Mazda who said they don’t understand why the servicing isn’t being done, but it’s not wear and tear tbh, it’s a hazard that exists in this car and as I’ve been finding, many others too. It’s not an easy fix. Can cost thousands and it depends on if it’s a warranty covered part or not. But it’s barely been driven. The car shouldn’t just have malfunctions out of no where.
Are you an attorney?
No but I’m getting involved with one.
If your car is still under warranty take it to the dealer and get it fixed.
Warranties are tricky, they don’t just cover everything, it’s not the damage. It’s the matter of it being such a malfunction that it’s causing an unsafe driving condition. It’s not wear and tear, 4 sensors malfunctioning on an car that’s barely been driven isn’t wear and tear,
I’ve actually found tons of people on other forums. And there’s pre existing lawsuits about this. So im sure Mazda is aware!
And yes but I don’t tailgate my traffic! The car isn’t picking up anyone in front of me and it’s also not setting the brakes correctly. My Mazda app gave me a critical safety alert and said do not drive the car, pull over immediately and put wooden blocks in front of the tires, park on flat surface.
Then maybe u haven’t been on enough forums? I’ve already got many people with the issue. U can also do a quick google search on this. It’s on the internet if u know how to use it.
It’s not unheard of for Mazda. Do a google search. I’ve already seen many people on Facebook with the same problem.
Just took it to the dealership who said nothing was wrong with the car and then said I needed to pay a ton more to do a more in depth look….
Most of us here are pleased with this car. Unlikely to approve this class action. I am sorry to see that you're going this route.
If you want to cite your sources (post links to the lawsuits you're referring to, links to the forum member posts you've found, and FB posts of people who have had this issue), that would help your case a lot. You'll need to provide all that info anyway if you plan to move forward with a lawsuit of your own.
I do find it interesting that you're willing to spend money on a lawsuit, but you won't spend a few bucks to further diagnose the issue and repair it. You'd have to do that no matter what, if you wanted to continue driving your car as your lawsuit progresses.
Anyway, some suggestions have been made by @RattleCanAR and @Z31 that may provide further insight into what could be causing the problem. I recommend at least looking into the insight provided so that you can get the problem fixed.
I had an old Toyota Sienna that was the same way. When the brake pads were worn down, it tripped the low brake fluid level. So when I saw these errors, I had a strong hunch that it would fix.
The other way to fix would be to just keep an extra 100mil of brake fluid in the reservoir, and then just be really careful with the last few mm of brake pad!
Hopefully our guy here can sort it out. Not surprising a dealership doesn't want to help at all without guaranteeing some $$. They hear brakes, and just jump to the easiest conclusion. I'd suggest take photos of the errors and upload here. No car is perfect, but haven't seen much evidence of chronic brake/electrical faults with Mazda.
