Vague Transmission Oil Change Recs Vs Common Sense & Reality
I still remember what Infiniti came to the conclusion of in terms of statistics on recommended oil changes on their new Q45 platform. They started out with a 60k recommended first change, and the transmissions were lasting 150k. They bumped up the recommended 1st change and the transmissions started lasting 250k.
I do it at 20k, based on the fact that the oil looks nasty at 20k...all of the early break in and manufacturing roughness is in the oil, so then does it make sense to use oil that has this much crap in it, that looks this nasty?
My guess is that it makes sense to extend the lifetime of a seriously expensive replacement item if you intend to keep the car long term or put a lot of miles on it. I just talked to the service manager, he says they recommend 80k, and they don't have much problems with transmissions.
I did mine at 120k because I bout it with that many miles and I don't think the previous owner had done it. I did it again at 150k miles. Right now I have 166k and trans is working like a clock. When I get a new car I plan on doing a 1x drain and fill every 30k
60-80k is ok on a Skyactiv. Yes you can do it earlier if you want but unless driving in extreme heat year round ... probably not necessary to do at 20-30k
Are you referring to the transmission fluid on the Skyactiv auto? What's your definition of nasty?
This is precisely why you want your first fluid change to be done early, I agree.
You already know the answer to this. In short, no. But, you have to also consider:
1. What's the bottom of your pan look like? Is it dirty?
2. How about the magnet? Is it filled to capacity with metal shavings?
3. And the strainer sitting at the bottom of the pan? Is it still "straining" the fluid properly, to keep the contaminants separate?
After 100k miles, so long as these three factors are accounted for, your fluid will stay clean, and the transmission will last.
It makes sense regardless of who drives it or for how long. It's an expensive components which requires appropriate maintenance.
80K starts to get a little late, but if you are dropping the pan at this mileage, that's fine.
It's true. I have 336,xxxKM on my Skyactiv auto; I was happy to see how smooth and precise the shifts were even when compared to the 2024 CX-5 loaner I had with only 36,000KM on it.
Driver claims that his transmission shifts "fine" at this mileage, even without ever servicing it. This is incredible for an automatic transmission.
Here's what the bottom of a Skyactiv transmission looks like after just over 100k Miles. (Drain and fill was done first at around 38k miles)
It's not bad, but that strainer and magnet needs to be clean, or else the transmission fluid won't be.
I got our 3's flushed out and ravenol ATF-FZ put in back in winter, at 50k miles... the old fluid wasn't bad, just normal dark gray (it wasn't black yet, but fluid color is also never fully indicative of its condition either)... about 1/3 of the miles on the car are road trip highway miles, so if it was only in town miles the whole time, I would've flushed it at 30k
shifts way better than when it was brand new...
the money spent on the 3+ gallons of fluid, plus cost of paying my dealer to use their BG machine to flush it out was worth it in time savings and guarantee that 100% of the original fluid is out compared to very costly 12 gallons of triple drain and fills and not really have 100% of the old fluid out
I don't recommend flushing with something way more miles than what I have or unknown history... but we had ours since new and understood what driving conditions it went through, so it's perfectly fine to flush
I'm about to buy a stock CX-50 cooler though... twice as big as the stock one, and is the same thing used in the mexican CX-5
The Skyactiv auto doesn't even have cooler lines for hooking up a flush machine.
There is some risk in flushing an AT, if the transmission already shows premature signs of failure. Makes no sense to flush or drain and fill a higher mileage AT without dropping the pan. It's like changing your engine oil, but not the filter. Drop the pan.
you never heard of an adapter? :rolleyes:
You’re in Japan and things could be different. In the US MNAO (Mazda North American Operations) have never approved their dealers who can use an “after-market” ATF cooler adapter to hook up a commercial ATF flush machine to change the ATF. Any promise of an ATF “flush” service on CX-5 I’d ask to see the special ATF cooler adapter designed only for Mazda’s SkyActiv-Drive AT.
Valvoline MaxLlife ATF for Mazda’s SkyActiv-Drive transmission? No, I won’t use it. “Multi-purpose” fluids serve me no good unless I have no choice. I’d use only OEM ATF FZ or A7 (for newer MYs), or at least any name brand ATF with “FZ” or “A7” spec.
I would be very cautious about substituting a different fluid when you change it. Especially you have to mix a half of the fluid like the AT unless you can flush it.
I read somewhere that max life was good for fz so I used it. I think the viscosity is thicker on the max life which is why I hear a slight whine from the trans while driving but so far I've put 46k on since I did my 3x drain and fill with Valvoline. If I were to do it over I'd use Mazda atf fz
No, I don't think that a subtle change in part of your transmission's total fluid capacity would cause a whining sound.
Assuming the whining is coming from your trahsmission, that's an early sign of failure, which is unlikely to be caused in a small trnsmission fluid variation.
It's coming from the driver's side of the car under the engine only when moving and increased in pitch with increase in speed. It's a mix of whine and whistle noise reminds me of interference in a radio
Is it most noticeable between 50-60 mph in 5th and 6th gears?
