- Plano, Texas, USA
I’m kind of agree with your point. Front lower control arm bushing has been a weak point and had been “redesigned” many times by Mazda based on several related TSBs. Unfortunately the ball joint on it is also weak and problematic. So most DIYers especially in early days chose to replace the entire LCA with new bushings and ball joint pre-installed. The price usually was under $100 for a good new aftermarket LCA and it’s easier to replace.Going through all that trouble to replace LCA for just some Bushings.. hm.
Replace the end links first. Shop around. I think you'll be happy with the result.
Nowadays the cheap good LCAs are no longer available. With high labor cost, a LCA replacement job unfortunately now could be as high as $1,000+ like @ColoradoDriver just found out.
The lower arm bushing is trash construction. A user posted a video here where he had clunking coming from his as well. Mine is all wrinkled and ripped, I'm pretty sure some of my suspension clunk is coming from it. I ordered new shock absorbers and when I have it apart i'm going to remove that bushing and fill the holes with polyurethane. Hardrace actually sells a replacement bushing (hardened rubber) for that one bushing only (literlally, not including motor mounts, that is THE only bushing they sell for the car) for the CX-5/3/6. It also comes included if you buy the Hardrace lower control arm. They already figured out it was garbage lol. Luckily it's easy to remove as the LCA just has a projection that this slides over.
Not sure what you are looking for here. The ball joint on the 2014 is made to be pressed out. Especially if your car is a California car with no rust this should be a breeze. You need some decent snap ring pliers to remove the snap ring. Your press and 2 cups of the right size to press and receive the ball joint - though a ball joint tool (huge sturdy c-clamp and cups) will also work.
The tricky part is not pressing the ball joint but rather removing the pinch bolt that holds the ball joint to the steering knuckle and removing the ball joint from the steering knuckle. Again - with no rust this is not too much of a challenge, but for rust belt mechanics you have to know a few tricks. Heat and vibration on the pinch bolt may be necessary to avoid snapping off the head. Getting the ball joint out of the steering knuckle you can go nuts with a pickle fork since you are not reusing it. Sometimes getting some pressure on the ball joint with a long pry bar and hitting the steering knuckle with a hammer is enough to get it to pop out. Similar tricks with the outer tie rod - usually easier access to get a pitman arm puller on it and a couple of strikes with a hammer will get those separated from the steering knuckle. Good luck with your repair.
