I cleaned the carbon buildup on my 2017 Mazda CX5 recently. I made sure to mask off most areas and I guess some carb cleaner overspray reached some of the wiring/connectors. After letting the car idle and get up to temp, it suddenly shut off (no misfires or anything) and threw some codes.
The codes are:
Would this be a short in the harness somewhere? The wires so far look all fine. Or do the actual sensors need to be replaced. Trying to avoid paying for a towtruck to bring it into a mechanic.
The codes are:
- P0069 - Manifold Absolute Pressure - Barometric Pressure Correlation
- P0335 - Crankshaft Position Sensor A Circuit
- P0193 - Fuel Rail Pressure Sensor A Circuit High
