I have a 2003 P5 with 120k and recently had the clutch pedal go all the way to the floor with zero pressure. Upon inspection, I noticed the rubber section of the pressure line was leaking, so I replaced that - bled the system - and still nothing. There are no other leaks anywhere else in the system that I can find.
I figured after that I would replace the master cylinder, however, for the life of me I cannot get the push rod off of the clutch pedal.
So, with all of this being said I have two questions...
1. How the hell do I get this push rod off of the pedal?
2. What else do you believe may be wrong with my clutch?
Thank you.
Thank you.
