Or you could pay 100% attention to what's in front of you while: Turning, merging to the on-ramp, calculating traffic flow on the freeway, and noticing that slow driver in front of you, not trying to jab the brakes and get rear-ended, etc. and just use the accelerator. If you can't wait for the accelerator to work and the transmission to downshift because "it's too slow", can you really afford to be in a 2017 CX5 that's a full HALF SECOND slower to 60mph? Something to ponder...
You can turn on Sport Mode without taking your eyes off the road. It is located to the left of the shifter and I can turn it on or off without looking down on it. Being able to turn it on without taking your eyes off the road means you can still keep 100% attention to what's in front of you. You seem to be implying that the use or the act of turning on Sport Mode distracts the driver and lowers their ability to drive. I can tell you from experience it does not.
All of these things that you mention, "Turning, merging to the on-ramp, calculating traffic flow on the freeway, and noticing that slow driver in front of you, not trying to jab the brakes and get rear-ended, etc. and just use the accelerator.", are not impeded by turning on Sport Mode. I actually don't understand how those actions are affected with Sport Mode on.
I think you're just nitpicking at this point. Here is a feature, Sport Mode, that puts you right into the powerband to make the car more responsive, and you don't want to use it because you want to wait for it to downshift? I presented an example where Sport Mode can be helpful. I didn't present an example where not having Sport Mode makes the car undrivable.
LOL I am one of those people who think the CX-5 is slow. I think it could use 20-30 more HP or at least more low-end mid-range torque. While Sport Mode does not increase power, the extra response from the engine is nice to have.
Fine motor controls are the first thing you have issues with in a stressful situation, and they can draw your attention, create tunnel vision, etc. This is why Glocks do not have non-passive safeties.
I still don't get what fine motor controls mean in this context. You will not get tunnel vision when you turn on Sport Mode, I promise. Turning it on does not require a huge amount of brain power or body eye coordination. What I'm trying to say is that it will not make you an unsafe driver on the road.
I have often wished for a bit more power, but never a "sport button" that does nothing but lug the engine around a couple of gears lower than typical. Some sport-buttons firm up shifts, raise line pressures, and adjust suspensions. Those are useful for things. This? It's just...I dunno...a doodad? Most vehicles call this button "The Tow button". Do you see people on the Truck Forums talking about using their towing button to merge onto the freeway? WTF?
You cannot lug the engine of the CX-5 with an automatic transmission. Even more so in Sport Mode. Sport Mode puts you right in the powerband, usually at 4k RPM. There is no way that you will be lugging the engine at 4k RPM. Actually, there's just no way to lug the engine on an automatic transmission CX-5 period. Even if you use manual-shift mode and put it in 6th gear and try to drop the revs, the transmission will automatically downshift to keep you from lugging the engine. I mean there is just no way for the car in Sport Mode, to be in low RPM and high gear, which is what I understand "lug the engine" to be. It is just not possible. How can you be in 4k RPM and be in the wrong gear to be lugging the engine? It will have you driving around in 4k RPM in 3rd or 4th gear depending on speed on the on-ramp, but I promise you, you will not be lugging the engine.
The Sport Mode feature does not increase power, that is simply not what it was added for. Sport Mode puts you right in the powerband, makes shifts snappier and makes the throttle more sensitive. If you are fine with driving in normal mode, which is the only mode available if I'm not mistaken in the 2015 models, then you're golden. However it does not make it useless for the 2016 models and above.
Just because people are turning on Sport Mode when towing, doesn't mean it is a "Tow button". The reason they turn it on when towing is for the extra throttle sensitivity. Meaning they don't want to press harder on the gas pedal to get more response from the engine. They can always press harder on the gas pedal to get more power from the engine if they want to. Same thing when going uphill. You either press harder on the gas pedal, or if you turn on Sport Mode, the extra throttle sensitivity means you don't need to press as hard to get more out of the engine.
I can see manual shift mode possibly yielding faster times if you drop it to a gear that puts you at 1k or 500 RPM below the fuel cutoff, versus Sport Mode with the shifter on D, but I think the differences in times won't be that significant. I mean how long can you stay at 5.5k - 6k RPM to extract power before having to shift to the next gear becuase of fuel cutoff. Even taking into account perfect shifting and not triggering fuel cutoff, which can be jolting, having to manually shift to the next gear will lose you some time versus being at 4k RPM and going WOT from there. If someone can test the differences bewteen these driving modes, I think it would be an entertaining read.
