The Official Mazda2 Wheel Thread
ImageUploadedByTapatalk1436105336.722637.webpImageUploadedByTapatalk1436105348.104215.webpImageUploadedByTapatalk1436105363.287429.webp
Avid av-08 185-60-15
Getting rdy for 195 50. Dz102s
Depends on a lot of other things. To narrow it down the most you need to think about the diameter of the tire. So assuming you are not going to drive around on a 275 hoosier, then that pretty much limits you to a 225. I say pretty much because I know there is a Toyo out there somewhere which is a 245 with the correct diameter as a 16", but I am ignoring that as well. So pretty much you are then limited to a 225/45/15 which can fit pretty easily depending on the front camber mostly. I track that size with -3 degrees of front camber.
For the wheel you pretty much need to run a 8". A 9" hits the front strut depending on the offset, and to push it out you will probably hit the fender with the tire.
Zach
Zach
I guess I should have been more specific. That's my fault.
What about the max size without rolling or adjusting camber?
Safely and exactly. 15x7.5" rim with a 42 offset and a 205/50/15 tire. A 225 will fit, but will rub in the rear on a car that's lowered more than 2". With the 205 and exactly what is listed above, no concerns whatsoever ever on ride height.
Thanks a ton! :)
My new Setup October 2015
- Advan Racing RZ Replica (Graphite)
- 17"x8.0" ~ ET40
- 205/40/17 Maxxis
- Muteki SR48 black lug nuts
- H&R Spring
OLD SETUP --> SIGNATURE
New to the mazda 2 world but its a work in progress.
2011 Mazda 2
16x7 Enkei J10 42 Offset
205/45/16 Hankook Ventus V2 concept2
threw on some TSM 16x7 et40 wheels today with snow tires (205-45-16r)
ready for winter if it ever snows, feeling stoked
ImageUploadedByTapatalk1457282008.582769.webpImageUploadedByTapatalk1457282050.089489.webp
205 50 r 15 Dunlop dz102 with Avid AV-8 wheels. 15x6.5 35 offset.
Wheels are crap but look great. Thinking of getting Rota Grids instead
Hypergram 15x7.5 +35, neo-gen 205/50, ~-1.5 deg camber; color is matte grey, but looks more like gunmetal.
