I bought my 2011 M2 in February and all is fine and dandy, loads of fun to drive even if it does get buffeted about on the highways. For the most part we drive it on mountain roads.
Couple of months ago the brakes began acting up. Sometimes they activate as soon as the pedal is applied, other times I'm standing on the pedal to slow down or stop. It doesn't matter the road conditions, the distance, or the weather. More recently we hear grinding when braking, whether it's a hard brake or a gentle brake.
I took it to a local shop and they found nothing wrong, plus on the test drive noticed nothing unusual. That's not surprising as the problem is intermittent.
Drove down the mountain and dropped it off at the dealership (Ford) for them to look at as its under a Certified Pre-Owned Vehicle warranty; they looked at the pads, calipers, rotors, lines, found nothing wrong, but suggested I take it to their sister store which happens to be a Mazda dealership.
Well, it got really cold for awhile, so I'm leaving loads of slow-down room anyway, what with the snow and ice and all. Twice the brakes failed to work at all, thank goodness for the e-brake. Fortunately we ended up in a parking lot and they worked just fine getting to a more legit place. Second time, at 10 mph or less, they wouldn't work leaving the driveway and I ended up in a field. Worked fine when we pulled the car out and called the tow truck/roadside service.
The Mazda dealership took apart the brakes and did a full inspection, in addition to 2 test drives. One in the parking lot. They found nothing wrong. Both the master mechanic and the manager went over them. He said when the abs pump turns on it does make a grinding noise, and the brake pedal fighting back/pulsing is normal. Twenty miles later the brakes failed 4 times, heading through switchbacks and construction zones no less.
I did read elsewhere on this site that it's not unusual for the brakes to need floored when the abs activates, but this is all random! I love driving my little car, but not if it's going to kill me!
