Most modern cars could easily go well over 50,000 miles without causing the oil filter to go into bypass mode- they are changed far earlier for reasons of cheap insurance.
Exactly. Not having a roving testing lab, I change my oil when it's about the color and consistency of my morning cuppa java.
Where do you get this stuff?
The technician at K&N who was evaluating oil filters; direct quote.
Skyactive, Skytech, Skyline ... sooner or later someone will explain to me how an out-of-the-blue marketing phrase translates to a cohesive set of design and engineering guidelines. (Our family '67 Bel-Air proudly had "Body By Fisher". Nuff said.)
- if anything it could be considered a "low-bypass" design because it calls for a filter that requires a higher pressure differential before it allows oil to bypass the oil filter media (compared to conventional automotive oil filters).
Well, again you're referring to the point of failure of the item, not the point at which most people would PRUDENTLY choose to do a replacement. For me that always comes at at 5K, no more than 7K miles for the synthetic (blend) I use. I won't pay to put Amsoil or Royal Purple in a car that's a daily driver. Mobil One is not technically 100% synthetic oil. To me, that's less important than the fact that I can always get it, it's not much of a premium over dino juice, and it has predictable wear qualities. If I tried to keep a gas-powered car over 100K miles, I'd probably be more anal about it.
And Wix does make a Skyactiv specific oil filter for the CX-5.
Wix Part #57002 is only spec'ed for the 2.0 liter engine. Wix doesn't officially support the 2.5 liter (yet); same as K&N.
And it makes sense that Mazda would want an oil that is tailored to the needs of their Skyactiv high pressure direct injected engines because the durability of these engines over time will determine the outcome of the companies economic success or failure. The Mazda oils are produced by modern, well respected refineries in Japan to specifications that were developed working in conjunction with Mazda. It might be "penny wise and pound foolish" to choose a less costly alternative (to quote an old British saying).
I can have "respect" for a Sam Adams brewery but choose not to buy into their premium marketing campaign. There are probably no relevant specifications which are NOT encompassed in a SAE viscosity rating and the API (American Petroleum Institute) performance standard.
The other element is whether you want a shop to do all the work for you, or whether you want to inspect the underside of your car yourself. I'm not a big fan of employees who are generally relegated to the lube-oil-filter stall, and regard any visit to a service department as an invitation to pay to fix stuff that wasn't broken before I got there. I'll gladly pay $30 for oil and a filter, and do it myself twice as often as necessary. That's better than paying $60 and having somebody else change the oil half as often, and who may have a financial incentive to "discover" additional work for the shop.
