CheeseHelmet
No might buy one now.
Jeez, get that done already
I have a header so i guess cat on the mid pipe went bad huh ?
No, you're getting that code because you have a header. Look into doing the "non-fouler trick", if you're lucky it'll get rid of that code.
Vcts not worried will be getting the mp3 flash soon just the first 2 are my problem and also a frozen driver caliper now too !! Ugh
You should be worried, if that code is there for real (and not as a consequence of something else) then that means that your VTCS butterflies are closing on their own without the ECU telling them to! Changing ECUs would not change that fact.
