Oh man, sorry for being so late to the party guys!
JT: I just looked back at the text I sent you and realized I screwed up when responding to you. Good looking out and much appreciated for your help!!! I will get with you on your setup for the sealed top Catch Can system. That system eliminates the PCV and has a check valve in it which is required to be plumbed to the intake manifold for a vacuum source.
Ricktalife: Since you have the filter top catch can, you will need to connect the bottom port of the catch can to the Millenia S PCV valve that you have. You can also eliminate the PCV with this setup! Please PM me if this is your plans. I will give you part numbers and pictures.
The top fitting of the catch can will go to the valve cover side port. Block off the intake manifold nipples that the "T" was originally attached to. Also, Block off the nipple on the intake tube the valve cover side port was originally attached to.The proper size vacuum caps with a little RTV and mini zip ties does the trick real well.
The picture that Bikingpro posted of my engine bay is a great reference for your setup. I used AN-10 for mine, but you will need 3/8" OR AN-6 is the same thing if you decide to get braided. Since you have the hose barbs for all connections in your system, you can just push the hose on for connection and finish the ends with finisher clamps. They look just like AN style fittings, except they are hose clamps. Let me know if you need part numbers for any of this stuff.
I hope this clears things up. If not, Let me know before you buy anything so i can help you make sure the tanks perform as designed. Sorry you had to make new brackets for your setup. The ones I supplied were intended for stock location mounting. You must be doing some relocations for the intake piping?? The catch can came with a mount for the battery tray, did you find a better spot? If so, please be sure to have it in a cool place away from heat and slightly lower than the valve cover. The hose routing should be so that there is a smooth transition downward from the VC to the catch can. This will keep from any pooling inside the hoses.
EDIT: I hate my camera lol. It looks like there are flaws in the paint job, but I assure you thats just reflection. The paint was a custom mix using several layers of candy blue over silver. The top coat has the ultra fine metallic in it and makes the color look like it has depth. If my camera wasnt such a piece of crap, you would be able to see that. High solids PPG clear, and my home brew of paint was used... hope you guys like it. Its one of my all time favorites.
