just put a small amount of white lithium grease on the tip of your finger and smear it on both belts when car is not running....then start your car...you should be fine...don't replace the belts unless is bad....
https://www.amazon.com (commissions earned)
Why would you grease a belt?!
I need to replace the belts on our 2003 P5. Are any of you aware of a decent write-up for the repair? I'm have some experience with repairs, but detailed walkthroughs are still nice to have.
Thanks!
Thanks for the reply. That is good to hear that its a relatively easy fix. We also need to replace the front motor mount (radiator side). Do you guys have any experience with that one?
Thanks again!
