The rear cross member is not reinforced at the mounting holes? I don't think it will matter to be honest. What's the difference between cross members? Just structural reinforcement @ the mounting holes?
From what I've been told one of the differences is that they utilized different mounting points for the rsb. The MSP rsb will fit the P5 cross member but the alignment of the mounting holes is off just enough resulting in premature bushing wear causing the dreaded clunk. That and price...the MSP is $93 and the P5 is $173 (taken from OMP). I know Ivan has the MSP cross member, maybe he's aware of any other differences?
Ok, I didn't realize the mounting locations differed. Try hitting up one of the numerous MSP part outs on here. I'm sure you could find one for relatively cheap. I think they weigh less than 25lbs. So shipping won't be too crazy...
Don't remind me...that was a long day....ha ha ha j/k buddy.
well today, i drive a friend to a local performance shop that he is having his work done at
get out of the car (turbo timer still running) walk around the back, and the car is ******* smoking out of the exhaust (pissed)
so apparently my turbo seals are taking a s***, slowly but surely, and i really dont want to buy another t25 when i plan on upgrading to a t3/t4 soon anyways
damit, great timing
Was the swap that bad, Chris? I've been thinking about doing it all day long (having the sheared nut in my current cross member has been helping).
It would be easy in Cali. Alas, the rusty underbody (as I'm sure yours is rusty in PA) typically poses problems. Lots of WD-40/PB Blaster, a torch, torque wrench/air tools and a tap/die set will probably all make the job quicker & easier. ;)
...let's just say this. I work at a dealership that has lifts, air tools and I've got quite a bit of experience and it took me the better part of a day to swap the cross member. I would never even think about doing this in a garage on jack stands. Those darn toe links were the hardest part.
So effin' true.....I hate rust! Should I decide to re-use my stock rsb, it's getting sanded down and painted. Although I was able to rip most of the current paint off by hand. I've got the PB Blaster on hand and access to a torch, tig welder, air gun and tap/die set via my neighbor. :)
Still not sure what I'm going to do....first things first I want to figure this current problem out.
I have the msp rear subframe and yes, the msp one is reinforced to accommodate the thicker rear sway bar. so, yea the mounting holes are different.
is that what you guys are asking? i can take pics of both if needed. (when I get home later today)
(nervous) Well that isn't helping with the confidence. lol Thanks for the input though.......
When re-installing the rsb is it necessary to use a jack on the brackets? I've read where some people did....maybe this is why I'm not getting it to 'line-up'? If I place the rsb on the top bolts of the rear cross member and place the rsb above the lateral link it extends well past the lateral link and the MSP end links are too long.
If I place it below the lateral link, the endlinks are waaaay too short and it sits almost even with the lateral link (meaning if I attach the end link to the tab and pull up on it the ball of the end link hits the lateral link. Sorry, I don't have any pics....that would make it so much easier to try and explain.
Got my new upgraded pulley for the supercharger.....=)
Has anyone done the crank pulley before? lol
Attempted to install my rear end links last night.....
Long story short...after cutting off the stock end links when I lowered the car, I bought the MSP end links as my research showed that I now needed the longer links to keep the rsb (note: I am using the stock P5 rsb) from flipping 180 degrees. Well, jacked the car up last night and the links were a wee bit too long....so I started thinking that maybe I had to drop the rsb below the lateral link. Removed the rsb and placed it below and now the end links are too short?
I've read the how-to for the MSP rsb install and done some other searching which all leads to me needing the MSP end links but it's looking like the stock P5 are what I need....any other suggestions?
Oh, and I sheared one of the nuts found inside the crossmember when I loosened the bolt with an impact gun....took about 20 minutes to remove that bolt/nut....good times.
Cool...so it is reinforced....good to know. See my initial post above as to how this convo got started....any suggestions?
And guess I should have started my own thread.....
It's not a "hard" project. It is very frustrating though. Like I said, it's those darn toe links that took the longest. Have you seen the sway bar links I made? They work great, and are a million times stronger than the flimsy stock ones.
damit, great timing
how many miles you got on the turbo? are you sure its not just over oiling it? I did that to mine when I had the VF-22. I upgraded the oil feed line from AN-4 to AN-6. Check your pipes to see if you are getting oil from any other source like the PCV/ valve cover. My turbo didnt last very long after the coking and leaking started happening. Went from slight sqealing sounds to full blown failure in 2 weeks! Hope you figure something out man!
Is the "lol" mean that's a sarcastic question? If not, the crank pulley is a piece of cake. Ask member KZL_99ES. He had his on and off from start to finish in 30 mins. heh-heh
I didn't get a chance to see them but you did tell me about them. If you have time could you pm me the info on where you bought the parts and what exactly I'd be looking for. An adjustable link at this point may be the way to go.
its the stock MSP feed line, so i think its a 3AN...not 100% on that
and as far as mileage, i have no idea, i bought the turbo from another guy with a turbo p5
no other oil could be getting by, i dont have the valve cover hooked up to the intake in any way, just the PCV to the intake mani if that makes sense
the turbo hasnt been spinning like it used to once i shut off the car, so i figured its just the turbo showing its age
Sounds good! Thanks!....still gotta find a belt though...
ok, I think I know whats wrong.
when you mount the sway bar, the bar should be as level to the ground as possible. if the bar is pointed in a downward position, then it will flip like what happened to you.
now it would be to your benifit to get adjustable endlinks. This should elimiate your troubles.
going back the reinforced tabs...look at these pics. its hard to see in this pic, but if you look where the bushing mount, you will see a small reinforced tab. this is the only difference between the msp and stock p5 subframe.
msp subframe:
now, look at this one (P5)
pay no pay no attention to ms paint markings lol
now, it should look like this when done. notice how the bar sits level with the ground.
does this make sense?
