From what I've been told one of the differences is that they utilized different mounting points for the rsb. The MSP rsb will fit the P5 cross member but the alignment of the mounting holes is off just enough resulting in premature bushing wear causing the dreaded clunk. That and price...the MSP is $93 and the P5 is $173 (taken from OMP). I know Ivan has the MSP cross member, maybe he's aware of any other differences?
Was the swap that bad, Chris? I've been thinking about doing it all day long (having the sheared nut in my current cross member has been helping).
The rear cross member is not reinforced at the mounting holes? I don't think it will matter to be honest. What's the difference between cross members? Just structural reinforcement @ the mounting holes?
...let's just say this. I work at a dealership that has lifts, air tools and I've got quite a bit of experience and it took me the better part of a day to swap the cross member. I would never even think about doing this in a garage on jack stands. Those darn toe links were the hardest part.
Attempted to install my rear end links last night.....
Long story short...after cutting off the stock end links when I lowered the car, I bought the MSP end links as my research showed that I now needed the longer links to keep the rsb (note: I am using the stock P5 rsb) from flipping 180 degrees. Well, jacked the car up last night and the links were a wee bit too long....so I started thinking that maybe I had to drop the rsb below the lateral link. Removed the rsb and placed it below and now the end links are too short?
I've read the how-to for the MSP rsb install and done some other searching which all leads to me needing the MSP end links but it's looking like the stock P5 are what I need....any other suggestions?
Oh, and I sheared one of the nuts found inside the crossmember when I loosened the bolt with an impact gun....took about 20 minutes to remove that bolt/nut....good times.
I have the msp rear subframe and yes, the msp one is reinforced to accommodate the thicker rear sway bar. so, yea the mounting holes are different.
is that what you guys are asking? i can take pics of both if needed. (when I get home later today)
well today, i drive a friend to a local performance shop that he is having his work done at
get out of the car (turbo timer still running) walk around the back, and the car is ******* smoking out of the exhaust (pissed)
so apparently my turbo seals are taking a s***, slowly but surely, and i really dont want to buy another t25 when i plan on upgrading to a t3/t4 soon anyways
damit, great timing
Got my new upgraded pulley for the supercharger.....=)
Has anyone done the crank pulley before? lol
Is the "lol" mean that's a sarcastic question? If not, the crank pulley is a piece of cake. Ask member KZL_99ES. He had his on and off from start to finish in 30 mins. heh-heh
Cool...so it is reinforced....good to know. See my initial post above as to how this convo got started....any suggestions?
And guess I should have started my own thread.....
